Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 09-12-2005, 04:19 PM   #1
sonnysmr2
sonnysmr2 is an unknown quantity at this point
full lock, wheel wobbles...
i have a s13, lowerd on old school jic coilovers, with tein tie rods, and spacers, no tir rod ends. since i installed these i have gained alottt more angle. the problem is now that i have installed them, when im at full lock my steering wheel and wheels will wobble really bad, sometimes to the point where its hard to pull the wheel out of full lock... i dont know how to fix this problem, is it too much toe, too much angle, or am i getting bump steer from the lack of tie rod ends.. any info would help, i have a track day coming up thur! thanks
sonnysmr2 is offline   Reply With Quote
Old 09-12-2005, 05:15 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
s chassis do that a lot. i thought it was just my car until i spoke to some people about it, and a pro drifter who confirmed that it's normal. I hate that feeling.
Hi
Old 09-12-2005, 07:30 PM   #3
chmercer
chmercer's Avatar
too much angle. when the car is going straight the control arms are in a triangle shape, as you move the wheel further to the left or right the triangle elongates getting more similar to a straight line, obviously less stable. nothings broken, just deal with it.
chmercer is offline   Reply With Quote
Old 09-12-2005, 11:23 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
and your tires could be rubbing on your frame.
Originally Posted by PHLIP
Old 09-12-2005, 11:49 PM   #5
sonnysmr2
i have a bunch of clearance i know my tires arent rubbing, i added more toe in, that seemed to help quite a bit.
Old 09-28-2005, 05:40 PM   #6
CAMFabrication
CAMFabrication's Avatar
CAMFabrication is on a distinguished road
Send a message via AIM to CAMFabrication
Explain how it woobles alittle more indepth, I'm sure there's an engeering flaw that can easily be exposed and solved.
Green Beret.
Your online friend is not one.
CAMFabrication is offline   Reply With Quote
Old 09-28-2005, 08:16 PM   #7
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
prolly too much angle, and not having TC rods. that hard pull is when you steer with the wheel to much and not the throttle.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 09-28-2005, 08:37 PM   #8
Dousan_PG
Dousan_PG's Avatar
high caster and too much angle
it shakes hard back and forth
reduce caster shoudl help
mine did when i was running the spacers w/ like 9 degrees caster it would shake.
Aaron
Pink GodziRa
Old 11-19-2011, 01:49 AM   #9
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
Ancient thread but I found it "searching" to STFU... anyways I am having this happen to my car, at full lock the wheel shakes violently and gets stuck at full lock... is this just going over center?
JSimpson is offline   Reply With Quote
Old 11-19-2011, 04:13 PM   #10
!Zar!
!Zar!'s Avatar
Yeah, that is over centering. If you have stock knuckles, adjust your caster to fix it.
Or purchase offset steering rack spacers.
Old 11-19-2011, 05:04 PM   #11
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
I have the parts shop max v1 SAK knuckles, tein inners and outers with spacers, chopped bumpstops, 7 degrees castor, -2.3 camber and a little toe out along with the steering rack moved forward about 10mm. I seem to over centre a lot drifting in the rain, not so much on the dry but still sometimes.
travypoo is offline   Reply With Quote
Old 11-19-2011, 05:31 PM   #12
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
Remove some caster and you wont bind as much
Need automotive work done in the antelope valley?
Ask me how i can help.
tt99ol is offline   Reply With Quote
Old 11-19-2011, 08:22 PM   #13
JSimpson
why does castor make the wheel bind? assuming it isn't going over center caster shouldn't make it "bind", but maybe the dragging of the lower control arm forward (to gain caster) would cause it to go over center
Old 11-19-2011, 08:25 PM   #14
Carbomb
Carbomb is an unknown quantity at this point
Home sells a subframe to fix this.
I have it , works well. same as offset rack spacers.
Carbomb is offline   Reply With Quote
Old 11-20-2011, 01:38 AM   #15
tt99ol
tt99ol's Avatar
Yeah it's the relation of the lca to the inner tie rod that causes bind, or rather the spindles pivot point to the inner tie rod's pivot point, the farther forward you get the inner tie rod's pivot the less bind and more control you have
Old 11-20-2011, 02:29 AM   #16
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
check your lower flca pillowballs. might need replacing. mine did that i replaced them and it fixed the wobble
joshchewuhh is offline   Reply With Quote
Old 11-20-2011, 03:54 AM   #17
!Zar!
!Zar!'s Avatar
Aren't most people moving the rack 25mm forward or so?
Old 11-20-2011, 12:07 PM   #18
chiboy002
yeah, look at C's garage, they did a write up
street dancer.
GLEAM
chiboy002 is online now   Reply With Quote
Old 11-20-2011, 01:27 PM   #19
word sux
word sux's Avatar
word sux is an unknown quantity at this point
dang drifters sells a modded subframe for $150
word sux is offline   Reply With Quote
Old 11-20-2011, 03:18 PM   #20
JSimpson
shouldn't you just move the rack as far forward as the spindles were shortened? Thus everything would be parallel again
Old 12-04-2011, 07:15 PM   #21
yellowcr
yellowcr is an unknown quantity at this point
last time ur wheels were balanced??
yellowcr is offline   Reply With Quote
Old 01-02-2012, 11:41 AM   #22
otto_3478s
otto_3478s is an unknown quantity at this point
It wobbles because the outer tie rod is moving in front of the rack, when you go past the center line of the rack, it puts the tie rod in a bind because you are pushing and pulling the knuckle back from the center line. If you look at an overhead view, youll notice that when your experiencing wobble, the outer tie rod end will travel in front of the center line of the rack. So if you REDUCE caster, you are effectively pushing your control arm back into the wheel well, this also pushes the tie rod end back enough to not exceed the center line of the rack.
Angle mods are rad if done correctly, honestly most people would be better off with rack spacers and a lot of caster. You can make gobs of angle with a PROPERLY adjusted suspension
otto_3478s is offline   Reply With Quote
Old 04-25-2012, 04:16 PM   #23
driftiteasy0313
driftiteasy0313 is an unknown quantity at this point
so would buying rack spacers fix this binding concern?
driftiteasy0313 is offline   Reply With Quote
Old 04-25-2012, 05:18 PM   #24
fckillerbee
fckillerbee's Avatar
DID YOU READ ANYTHING?
over and over they said how to fix it.
