![]() Join Date: Mar 2003
![]() I have a 1992 SE with the stock KA and I was driving to work yesterday morning, stopped for gas, then got back on the freeway when all of a sudden my check engine light comes on. I pulled over and looked everythign over and it seemed fine so i kept driving and the light would keep coming on then going off. really weird, but the car was running ok. On my lunch break i pull the code from the ecu and its a 34 = knock sensor. So when i drive home now the car wont idle and keeps stalling when i come to a stop. It is also pretty stuggish when accelerating. My question is could all of this be related to the knock sensor? Ive also heard that the CEL wont even come on for the know sensor? but i dont know if this is true. Could it mabey be a bad ground and that is why the ecu thinks the KS is bad and could be the reason for the car stalling? could a clogged/dirty MAF cause all of this? Any help would be great.
thanks |
LAID OUT
![]() Join Date: Mar 2004
A few quick suggestions...
Check all your vac + elec connectors, wires, hoses for shorts or leaks Check engine grounds Clean battery terminals Clean your MAF with TB cleaner I had a code 34, ended up being a short in the wiring from the knock sensor to the ECU, in the harness from the ECU to the KS Subharness connector. This made the ecu believe the engine was knocking, so it would pull timing and cause the car to bog and just generally drive like shit. Here is my thread on the topic you might find something in there that helps you... http://www.zilvia.net/f/showthread.p...ht=serious+bog GL |
#3 | |
thanks |
code 34 knock is on my car. it doesn't affect the idle or anything.
however, iirc according to the FSM, the knock sensor will retard timing when it senses knock; so maybe its reading inaccurately and screwing with your timing, making your car idle funky and run like shit. i have to reiterate that just about every 240sx will throw a 34 at some point; and in three years of forum whoring and talking to people ive never heard of it causing issues like yours. |
