Old 09-23-2005, 11:07 PM   #1
prymer 240
prymer 240 is an unknown quantity at this point
s13 tranny leak from shifter
aight.. i filled up my tranny 2 3/4 from the shifter.now when i put it back and driving around or wat not... it seems the gear oil is coming out from were shifter boot is..i was wondering if i put the shifter in right...firt i slapped the shifter in... then i put the small C clip in.. kind of just laid there....i dunno y... and the i put the larger C clip in.is that the right installation...the samller C clip kind of got me thinkin if it suppose to jus lay there or hold n e thing down or wat not....can n e one help me??
prymer 240 is offline   Reply With Quote
Old 09-23-2005, 11:10 PM   #2
aznpoopy
aznpoopy's Avatar
there is a gasket that sits between the tranny and the plate /w t3h 6 bolts. if its fucked you'll leak a ton of gear fluid from around that general area.
Old 09-24-2005, 01:28 AM   #3
Irukandji
ditto...check that, if you cant fix the leak,rtv it!
Old 09-23-2005, 11:13 PM   #4
kandyflip445
kandyflip445's Avatar
You can use RTV to seal it.
My 240 vBgarage
Old 09-24-2005, 03:26 AM   #5
S14DB
AFC #1
S14DB's Avatar
you overfilled your tranny. Fill it from the fill plug next time.
Old 09-24-2005, 10:02 AM   #6
prymer 240
to azn poopy,, i didnt remove the 6 bolts, i jus took the c clips out and popped the shifter out. mayb i over filled it
Old 09-24-2005, 11:59 AM   #7
projectRDM
projectRDM's Avatar
2.5qts is full and you probably had a little left over in the case, so you overfilled it.
FORMERLY R240NA
