Old 09-27-2005, 11:07 PM   #1
janko
janko is a well-known jackass
Is this a problem with my block?
These are pics from around the water pump area on the block. The second pic is if you're looking from the left handside of where the water pump would mount. I found this today when I was taking all the sealant off, I have no idea what could have happened.
'92 G20
'96 240sx
janko is offline   Reply With Quote
Old 09-28-2005, 09:19 AM   #2
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
Looks like there was a hairline crack that chipped off a little bit. Why did you pull the water pump anyways? Is this on your Spec V? If you pulled it off for a coolant leak this is your problem and it will be an expensive one to fix.
'93 Pathfinder SE daily driver
'93 HB blue (under construction)
'89 Celica GTS RIP
SHIFT_control is offline   Reply With Quote
Old 09-28-2005, 10:24 AM   #3
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
even i wouldnt jb weld that, bring it some place and have them fill it with aluminum weld
tastyratz is offline   Reply With Quote
Old 09-28-2005, 11:33 AM   #4
janko
No, its an SR20DET redtop block for a 240. The guy I bought it from said he had no problems when he was running it. He also said he didnt have any coolant leaks.
There was a problem with the second picture, its fixed now.
'92 G20
'96 240sx
Old 09-28-2005, 11:57 AM   #5
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
Thats fine, thats the way they look, my S14 SR20 also looks like its cracked off there, as are every one of the 30-40 SR blocks ive worked on.
No problems, throw your pump on and go
Rezlo is offline   Reply With Quote
Old 09-28-2005, 03:42 PM   #6
Rezlo
Thats an S13 block i did for a customer, as you can see if you look carful its just like yours with the little bit missing, got me worried when i saw that on my first SR build
Old 09-28-2005, 04:23 PM   #7
janko
Thats weird... Thanks for your help, any ideas how to get the metal piece out that its in the second pic?
'92 G20
'96 240sx
