Old 09-30-2005, 11:01 PM   #1
driftkid316
driftkid316 is making a name for him/her selfdriftkid316 is making a name for him/her self
Send a message via AIM to driftkid316
will i lose torque when going hi comp?
just wondering, if i were to go hi compression in the kade, would i lose any or alot of torque. just wondering because im considering going that route and dont wana lose the wonderful torqueyness of the KA. also, going hi comp, is it gona eat up my gas more like when turbocharging? would i have to up the injectors like in turbo cars also? thanks for the helph
driftkid316 is offline   Reply With Quote
Old 09-30-2005, 11:24 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Would gain torque since there would be more force per combustion event. Yes it will eat more gas and you are going to have to use premium.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 09-30-2005, 11:30 PM   #3
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
won't it be eating more gas above certain rpms?? i.e. 3500 rpm.
I can imagine shitty city gas mileage on a hi-comp.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 10-01-2005, 09:36 AM   #4
wootwoot
It will eat more gas at every rpm
Old 10-01-2005, 11:47 AM   #5
S14DB
AFC #1
S14DB's Avatar
How will it "eat more gas?" Please, explain the physics to me wootwoot...
Old 10-01-2005, 11:51 AM   #6
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
i seriously think it'd be more productive to build a supercharger kit than to build a high comp NA KA powerplant. you'd have torque and that wonderfull blower whine.
MakotoS13 is offline   Reply With Quote
Old 10-01-2005, 12:23 PM   #7
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
i had an alternator with an open diode and it sounded like i had a supercharger.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-01-2005, 03:18 PM   #8
Andrew Bohan
my hi comp ka was fun until i blew it up. (about 150 miles once i got it running right).
it was definately more powerful than a stock KA, but not quite as powerful as a stock SR. maybe about 3/4 of the way between KA and SR. torque was maybe a little closer to SR than that.
Old 10-01-2005, 03:20 PM   #9
wootwoot
I'm actually not to sure now that I started to think about it. A higher compression motor uses the same volume of air it is just compressed more before ignited. I was thinking "more air is compressed so more fuel must be added" which isnt true. My mistake, had never really thought to much about it before. Is that second thought right atleast?
Old 10-01-2005, 07:46 PM   #10
S14DB
AFC #1
S14DB's Avatar
Yeah, the higher compression the faster the fuel is burned. The faster the fuel is burned the more power you get from the charge. Displacement or Volumetric Efficiency changes are the only reasons you would add fuel. You are increasing the amount of Air getting into the cyl. so, you must increase the Fuel. Higher octane fuel burns slower to reduce chance of pre-ignition. but, also doesn't produce as much power.
Turbo/Supercharging increases the VE while artificially increasing the Displacement and CR.
