missing stuff on tranny
i got a tranny for my 5 speed swap but everything is missing on it.. like the throw out bearing assembly, sensors, and switches
what should i do? buy a new tranny?? or buy everything |
this is my bellhousing.. you put the throw out bearing on that shaft right? is there anything else i'm missing besides a fork? is there a second part to the TOB? i was told that the throw out bearing is too small and theres something that mounts it on.
![]() Join Date: Jan 2005
Trader Rating: (29)
Before you do the swap read every thing that you can find on doing it. There are several very good posts on doing the swap in archives. By the way I would try to find a switch for reverse lights from somone, new OEM from Nissan they are $45.00. http://www.zilvia.net/f/showthread.p...ighlight=trans This is a great thread. |
#9 | |
![]() Join Date: Dec 2002
i went to http://www.overnightautoparts.com/
i'm ordering a Release Bearing Retainer Spring and release bearing holder for a total of 20 dollars.. do i need a clutch release arm also? i have a fork and TOB already |
No more nissan.
![]() Join Date: Jan 2003
yes, or here. www.courtesyparts.com
if it's not listed, call..
#16 |
Trader Rating: (29)
Your pic needs a little help, but I think the first one is your reverse light switch. If you have a continuity tester check across the two wires both without pushing on the switch and depressing it. Without depressing switch= no continuity. Depress switch = continuity, then switch is good. That should work for all the switches. Only one you realy need is reverse lights, the others will fill the holes in your tranny nicely.
#17 |
alright i finally got all my parts together.. here's what i have
![]() i have: Manual Transmission Shifter Release Bearing M/T Mounting plate Clutch pedal Crossmember Driveshaft (other half not in pic) Brake pedal (From M/T car) Clutch master cylinder Clutch slave cylinder Hydraulic Lines: i only have the rubber one attached to the clutch slave Shift boot and plate 96 Manual ECU that i'm not going to use because I have a '97. I'm going to go with the Auto ECU until i get a 97/98 Manual ECU already installed on my car- Pressure plate Clutch Flywheel from a m/t stuff i have for the missing parts on tranny- clutch fork clutch alignment tool dust cover release bearing ordered a release sleeve and a retainer spring some sensors in the other pictures but i dont know which they are. here is what my tranny looks like.. ![]() ![]() is there anything else i'm missing besides a speed sensor and clutch hardline? i've searched through a lot of manual swap guides but none really answer my question. i spent a lot of time on this post, so if you guys could help me, i'd really appreciate it. thanks |
#18 |
No more nissan.
Did you switch out the pilot bearing before you installed the clutch and pressure plate? If not, yank 'em off and DO IT. And where the heck is the rest of your slave cylinder? The pushrod and such? Where and how much did you get s14 pedals for? And your s14 tranny.
And do you have both springs?
#19 |
i got everything for 800 in one package
the clutch slave cylinder.. i bought a brand new one from overnightautoparts.com that one in the picture just came with the package both springs to what? if it is the tranny you're talking about, i ordered a retainer spring i might be buying a 98 manual ecu soon, it'll just hook up to my harness i have right now right? anything else i need? thanks neme |
#21 |
Trader Rating: (29)
Looks like you are on the right track. If I may make a suggestion, I would suggest that since you are there you might want to change out your rear main seal, also the front and rear seals on the tranny. Rear main is about $25.00 and the tranny seals are about $5.00 ea aftermarket. I got mine at NAPA.
I see that you have your auto trans out...I know that was fun. Good luck with your swap I just finished mine. Be patient getting the manual back up in there can be a bit of a bear...My s13 was a little tricky, it may be different for the s14 |
#24 |
No more nissan.
NO NO NO NO NO for $100?! I paid $30 for a 95 and $40 for a 96 ecu SHIPPED!! Hold out until someone less stingy is selling a 97-98 ecu. haha
and reply to my PM damn you! ![]()
#30 |
![]() Join Date: Mar 2005
I just got my 5spd. done. I took it in on Nov. 23rd., recieved it Nov. 26th, all I had to do is supply them with a d/s. The whole thing cost me 600.00, thats (install+parts), the car runs like a dream! I was gonna gather all the parts myself and just pay for installation but a friend of mine told me just to let them do it b/c they know what parts are missing/broken/wearing out/etc. Now I'm happy to drive my car again, glad it is no longer automatic!
