Old 12-28-2005, 05:44 PM   #1
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
s14SR gasket set
Hope this is the right area to post this.....I just found out that my s14sr has a blown head gasket and have pretty much decided on the cometic hg, but i figured since the car would be down/apart for a while that I might as well replace all the gaskets....my question is are aftermarket gaskets worth it for anything other than the head...they sell a complete gasket set on ebay for approx 200.00...now I'm pretty sure that the oem hg is not gonna hold up when I get to my goal (300whp) so thats why I want the cometic but what about the rest...oh yeah my gasket budget is no more than 250.00..('gasket budget' now that sounds stupid )
DrtyRat is offline   Reply With Quote
Old 12-28-2005, 06:30 PM   #2
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
The HG is the big one that needs replacing on the SR. I would also consider replacing the valve cover gasket, and the turbo gaskets. I've also been told replacing the spark plug seals is a good idea, but not absolutely necessary. I think you would probably be all right with just the HG replaced at first for 300hp, and the others when you had the extra $$.
mRclARK1 is offline   Reply With Quote
Old 12-28-2005, 10:20 PM   #3
Dousan_PG
Dousan_PG's Avatar
300hp is Aok w/ stock headgasket
replace the valve cover ones, turbo ones (mani and all) and umm not muchelse. intake manifold too
phase2motortrend sells a whole kit for all that action in one i beiele. all OEM
Aaron
Pink GodziRa
