11-02-2020, 02:10 AM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
87 Nissan 200SX s12 s14 SR20DET build!
Hello my name is Christian I've been on Zilvia for awhile now and I've owned about 14 different s13s, s14s.
They are awesome cars however I wanted to build something a little different so I purchased this s12 off a guy in Long Beach for cheap back in August of 2019. It took me a full year to get it to where it is now, when I bought the car it came with full s13 front suspension stance coilovers, pbm arms rear s13 subframe conversion which not a lot of s12 guys do cuz its pretty hard tomei 2 way diff fully adjustable arms in the rear with Porsche shocks and z32 aluminum uprights this is how it looked when I had the car picked up(not me in photo lol): this one is a little rarer because it came with a vg30e but the car wasn't running and I had my mind set on swapping a sr in it so out goes the vg Once I had the motor pulled it was time to prep the engine bay for paint. this isn't a show car so I just rattle canned it black came out ok. Also before I painted the bay I made holes for the IC piping they're not perfect, I also added rubber grommet the rear hatch glass was shattered and trying to find parts like that for these cars is a bitch! its not like 240sx where there's plenty of parts luckily I found a guy in Oakland so I drove 5 hours to pick it up and this is how we strapped it to my friends Yaris lol Installed My rack&pinion was leaking so I got a new reman one from vatozone I also installed new bushings but didn't snap pics of that Alright so this is how I bought the motorset. the bottom end was already assembled and was bored .020 over has Wiseco 86.25mm pistons ACL race bearings Eagle H beam connecting rods head is stock, had oem turbo the motor was missing a few things I had to piece together but got everything for $1200 which I thought was a really good deal! Tomei head gasket I also used ARP head studs. the head was hot tanked and decked. and tested fresh from the machine shop getting there haha I also had the valve cover powdercoated ACT lightweight flywheel and exedy clutch transmission is mounted! putting the motor in for test fit. the sr bolts right into the s12 but since the car had a vg30 they sit higher so that's why I got bmw motor mounts to lower it. oh and I did all this by myself in my garage!! trying to figure out the intercooler piping. CX racing FMIC for s14 sr20det I cutoff the recirc pipe and had the BOV flange welded in along with the IAT sensor I'm surprised I got the FMIC to work with the s12 lol trying to figure out how the radiator was going to sit had to cut some of the bracing on the hood bought a Tomei cover and drive belts bought a timing chain tensioner from MAZWORX such a nice piece circuit sports 3 inch turbo elbow tomei 87.1mm headgasket Probably the best purchase I've made for the car is this wiring specialties universal standalone engine harness Tomei Expreme turbo manifold new oem oil return hose and bmw motor mounts lol 750cc five o injectors Garret GT2871r brand spankin new lol oh yeah swapping a couple things over to the new turbo, I did run the oem one for a bit but had to upgrade the water pump was leaking so I replaced with a new oem one! this is a must buy forsure
12-03-2020, 06:48 PM | #2 |
Trader Rating: (18)
Alright now that most of the motor is done, I swapped out the fuel pump for a walbro 255
old left vs new right then I installed a tomei 2 way that I got with the car relocated battery putting the motor back in late at night its in! lol had a extra pipe for the air filter bought a GK tech clear CAS cover all buttoned up |
12-04-2020, 11:36 AM | #4 |
Great parts, excited to see an S12 done right for once.
Question, do you know if all ACT flywheels aren't proprietary? What model is yours, and are you sure an Exedy clutch is compatible? Thanks! |
