Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 02-04-2010, 06:31 PM   #1
FullRaceGeoff
FullRaceGeoff is an unknown quantity at this point
RB Full-Race R14 at 2010 Modified Mag Tuner Shootout
EDIT: 2 good vids:
http://www.youtube.com/watch?v=-rbVCuz94QY
http://www.youtube.com/watch?v=Yr3avR2vyZ8
Hello fellow nissan fanatics, I have decided to turn my R14 (GTR-based S14) into a time-attack machine for the big modified tuner shootout race event coming up. it will go back to occasional street car duty afterwards (its too much fun not to drive on the street), but first and foremost I am working hard to make the car competitive for the event. We got 2nd place the last 2 years in heavily modified street subarus and we dont want to give that up. A street subaru wont get us 2nd this year - there will be a UMS's sickass evo 8, a dedicated track porsche 911 twin turbo awd as well as the sierra sierra cosworth evo and tarzan is driving crawford's STI so we have to be on top of our game to do well. We have 10 weeks before the event. The chassis and engine are VERY solid and have plenty of time on them with no problems. Our driver is Mike Speck - an ace behind the wheel and knows this track extraordinarily well. I am getting a set of motons, and they will be used only for the track with the aero package on the car (will switch out to my koni 28 series for the street).
Specs are:
full roll cage, proper bracing in the right spots
r34 gtr brembos front and rear, raybestos motorsport pads, brake ducting
R32GTR front suspension, caster changed to 7degrees through custom upper control arm mounts. Stock swaybar, Stock Upper Arms, Stock lower arms, Stock tierods, Quaife Front LSD, urethane swaybar bushings
R33GTR rear suspension, full adjustable links, R32GTR stock swaybar, nismo LSD
Tires are Hoosier A6 (Autocross compound for time attack) and BFG R1 (enduro + lapping) 275/35 on a 18x10.5
Torque Split is running fixed with 40-55-60psi in the transfer case (ATTESSA eliminated) depending on preference and tires/track condition
its a built motor, borg warner airwerks twinscroll turbo, expecting 680-700hp on E85 (e85 helps response and spool), good oiling system and cooling is getting improved right now
here are some pics of the engine setup while i was daily driving it (engine/turbo will remain unchanged) and the twinscroll borg warner S300SX 88-75 turbo, with 90 degree compressor housing.
-- pump gas dyno at 19psi. e85 tune will be at 30 psi and will generate much more area-under-the-curve
some pics of the changes were making now:
^^new vmount, improved radiator airflow
^^modified R32 GTR spindles to accept the 1/2" heims on the motons AND dropped the toe link 30mm to adjust for bumpsteer. will finish machining this weekend
^^surge tank with dual 044s, to run 100psi base fuel pressure on E85
thanks for reading, ill try and update this again when were making progress
FullRaceGeoff is offline   Reply With Quote
Old 02-04-2010, 06:51 PM   #2
jspaeth
jspaeth's Avatar
This thing is gonna be retarded!!!!!!!!!!
350 ft-lbs+ of torque from 4500-8000 in a 4 wheel drive 2700 lb car.
This should be insane, I wish I could watch in person.
Daily driven
Old 10-05-2010, 09:48 PM   #3
daviddwilson
daviddwilson is an unknown quantity at this point
WOW, ridiculous! Looks pretty perfect
Could you elaborate on how you control the torque split manually? You just regulate oil pressure to the transfer case or somethin?
Good luck in the time attack. Looks like the competition is pretty tough but i'm rooting for ya!
watch movies online
daviddwilson is offline   Reply With Quote
Old 02-04-2010, 07:11 PM   #4
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
96Turbo is offline   Reply With Quote
Old 02-04-2010, 10:14 PM   #5
RB24_S14
RB24_S14's Avatar
RB24_S14 is an unknown quantity at this point
holy shit. that is a monster!
460whp 350Z
RB24_S14 is offline   Reply With Quote
Old 02-04-2010, 10:19 PM   #6
MikeisNissan
MikeisNissan's Avatar
couldnt you atleast get some glass headlights? anyway badass car!
因果関係の流れ
MikeisNissan is offline   Reply With Quote
Old 02-04-2010, 10:20 PM   #7
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
beast!!!!!
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 02-04-2010, 11:08 PM   #8
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
u guys never released pricing for the s13 awd swap? im expecting it to be in the 13,000 range?
RPS13-604 is offline   Reply With Quote
Old 02-05-2010, 07:55 AM   #9
FullRaceGeoff
we will not be offering an R13 conversion kit anytime soon. HOWEVER - the main reason we are entering this race, to debut our DIY R14 kit in the magazine. In a few months we will be releasing a DIY-R14 kit that any skilled and competent mechanic with a 220V MIG can install. The price is going to be much lower than previous (please dont call the sales office bc they know nothing about this).
this conversion does not work in the S13 chassis nearly as well as S14.
This thing is gonna be retarded!!!!!!!!!! 350 ft-lbs+ of torque from 4500-8000 in a 4 wheel drive 2700 lb car. This should be insane, I wish I could watch in person.
To be fair, she weighs 2950lb, the RB26 is a huge bitch! However well be making much more than 350lb-ft in race mode so it will be exciting to watch. Just ordered (4) go pro HD cameras to get some good footy
Originally Posted by 96Turbo View Post
Could you elaborate on how you control the torque split manually? You just regulate oil pressure to the transfer case or somethin?Good luck in the time attack. Looks like the competition is pretty tough but i'm rooting for ya!
torque split in these cars is pretty simple, just variable pressure on a wet multi-plate clutch (just like inside an automatic transmission) so all you need to do is have a regulated control of hydraulic pressure on that wet clutch and thats what we developed our electronic attessa eliminator. im working on a complete install and FAQ for a total revampe of our R14 website and all this will be answered with pics and in depth info
glass headlights are heavier. the only thing the headlights will change to is s14a or s15
Originally Posted by sickstatus View Post
beast!!!!!
thanks guys!!
Old 02-10-2010, 12:54 PM   #10
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
this car only weighs 3000 lbs with the RB26 and the AWD? thats still light!
spooled240 is offline   Reply With Quote
Old 02-05-2010, 08:14 AM   #11
mr_eh
mr_eh's Avatar
mr_eh is an unknown quantity at this point
shazam, good luck with it, think it'll make it to the east coast this season?
mr_eh is offline   Reply With Quote
Old 02-05-2010, 07:45 PM   #12
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Dam ive been following this car since it was featured in Modified! Dam what hard work you have invested in that car, and it show's big time! Good luck on all the exposure it will be getting in the shoot out.
S14Serge is offline   Reply With Quote
Old 02-05-2010, 08:04 PM   #13
FullRaceGeoff
thanks guys, just spent all day welding some fender braces in (cage does not pierce the firewall) and working on the fuel system and belly pan. one of the gangster fabricators at Full-Race made some siiiick RUCAs, ill post pics up tomorrow, maybe some pics of the belly pan and jack points too
it might make it out to the east coast this summer, if not this one definitely next summer
Old 02-05-2010, 08:00 PM   #14
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
seriously.....now that's how you build a car!!! Props to you guys at Full Race and good luck this year!!!
Scott
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Old 02-05-2010, 08:09 PM   #15
Scott@FontanaNissan
Will we be seeing it at the Redline Time Attacks this year???
I'm currently selling my Street Class STi and will be building an S14 next! It's enlightening to see what you all have done with it!
Scott
Old 02-05-2010, 08:24 PM   #16
FullRaceGeoff
to be honest this is my fun street car, not really meant to be a competitive time attack machine. If we decide to compete in redline, i have (2) s14 shells that we will choose between for another R14... although what class would we be in? I really dont follow the rulebook, just build my cars how i want
Old 02-05-2010, 08:36 PM   #17
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
Wow, just wow. Your car is just absolutely beautiful. I love the paint, wheels, engine,......everything! Goodluck, Im sure this beast will come thru for you.
Erjay1 is offline   Reply With Quote
Old 02-08-2010, 08:30 PM   #18
FullRaceGeoff
thank you erjay, we just finished up sealing up the flat bottom from frame rails to side skirts, next up is the rear bumper diffuser and then the adjustable front carbon kevlar splitter..
Old 02-08-2010, 08:57 PM   #19
z2roll4life7
z2roll4life7's Avatar
z2roll4life7 is an unknown quantity at this point
This Car is So Sick I Remember seeing this in modified mag it was (and still is) The Best 240 ive ever Seen I cant wait for a Kit to Go on Sale ill work 100hours a week to Build a car like this You Guy's are inspiration Plain and Simple Keep up the Good Work
z2roll4life7 is offline   Reply With Quote
Old 02-08-2010, 10:47 PM   #20
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
very interested in this, more pictures please!
blackej7 is offline   Reply With Quote
Old 02-10-2010, 09:30 AM   #21
FullRaceGeoff
a cpl more pics
been working on the car some more and will take some pics this weekend. here are some random ones to keep the thread alive
^^^my kind of RUCA, plenty of strut clearance, easy to get replacement heims for, and it cost $50 in parts
^^how the heim will sit inside of the welded spindle I posted last time
^^^welded the fender braces to the sheet metal, these can make a difference if the cage doesnt pierce the firewall - but only if they are welded in.
^^its a huge hassle to jack a 240 with big sideskirts + i needed some stiff mounts for the bellypan aero - so we made these jackpoints/bellypan mounts
^^^sealed up the area from frame rail to skirts, and put a little dynamat in there to keep things quiet. will finish the center and f/r in 2 weekends.
more random pics:
Old 07-03-2010, 01:35 AM   #22
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
what is this front bumper??
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 07-03-2010, 08:13 AM   #23
FullRaceGeoff
bumper is from touge factory - version select!
Old 02-10-2010, 09:41 AM   #24
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
omfg so much win!
i hope you guys win, about time the s-chassis got some recognition all these damm evo/sti taking all the glory. this car is gona be epic.
i love your choice of bw turbo btw.
cant wait to see the final outcome!
p.s. kouki conversion kouki>zenki!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 02-10-2010, 09:49 AM   #25
juve_240sx
juve_240sx's Avatar
juve_240sx is an unknown quantity at this point
beautiful s14 and also the skyline
juve_240sx is offline   Reply With Quote
Old 02-10-2010, 10:57 AM   #26
FullRaceGeoff
thanks for the props, so what headlights do you guys wanna see kouki or s15? it will probabbly happen right after the race
Old 02-10-2010, 11:09 AM   #27
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
kouki front end is hot but i like the car the way it sits now.
reccakun08 is offline   Reply With Quote
Old 02-10-2010, 11:12 AM   #28
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
that thing is awesome!
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 02-10-2010, 11:33 AM   #29
PoorMans180SX
PoorMans180SX's Avatar
Keep it Zenki or go Kouki. S15 front doesn't belong on an S14.
Old 02-10-2010, 11:35 AM   #30
FullRaceGeoff
yes but s15 is the most aerodynamic...
full-race, gtr, r14, skyline, time attack
