Old 06-14-2002, 08:04 AM   #1
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
How much play should the clutch have when accelerating?  I drove my friend's mustang and my cousin's MR2 and there isn't a lot of play.  In my car I have to let go of the clutch almost completely before I start accelerating.  Is my clutch bad or is this normal on the 240sx?
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
Old 06-14-2002, 09:21 AM   #2
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
tech section?
there should be a 1/2 inch of play in your pedal that is freeplay before you can engage your clutch/disengage clutch.
check and make sure you have enough fluid in your master cylinder first. how many miles on your car? do you drive hard? burnout?
to test your clutch you can get up to 25-30 mph throw it into 4th it should grab and accelrate if you see your rpm's rising more than your speed. you have a slipping clutch.
there is also a archive/faq on here with some more info on clutch issues
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
