Old 02-21-2006, 12:25 AM   #1
driftkid316
driftkid316 is making a name for him/her selfdriftkid316 is making a name for him/her self
Send a message via AIM to driftkid316
TB worth boring?
im going to rebuilding my ka24de and am going to be doing a few things to it while at it. my setup is gona basically be:
intake
headers
full straight 2.5" exhaust
sohc pistons
balanced crankshaft
port head on intake side
port matched intake manifold
i think thats basically it. but my question is, is it worth boring my throttle body with the power ill probably be putting out? or would it mostly be reccommended for higher power cars like turbo cars or something. if it is a good idea, what the max bore i should do? thanks
driftkid316 is offline   Reply With Quote
Old 02-21-2006, 12:51 AM   #2
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
wait wait wait.
You're going to do the high comp KA with no 3inch exhaust?
EDIT: TB not worth boring. TB, single, not cool. ITB's plural, very cool.
Maeda is offline   Reply With Quote
Old 02-21-2006, 01:31 AM   #3
miked808
miked808 is a well-known jackass
Boring the Throttle Body is a good cheap mod. Slight power increase and very good throttle response. But the opening on The Intake Manifold where the Throttle Body bolts up will need to be opened up with a Dremel or Similar tool.
miked808 is offline   Reply With Quote
Old 02-21-2006, 01:37 AM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
or u can just hack the flange off and weld on a larger tb flange, and use a tb w/ a map sensor and tps sensor.... and get rid of the maf.... in general...
so ive heard of ppl running q45 maf and tb... but this is just what ive heard... nothing seriously seen yet...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 02-21-2006, 01:40 AM   #5
Maeda
Maeda's Avatar
I thought the q45 thing is an SR thing...
I'm curious...
Why are you throwing down money on NA KA and not t to the urbo?
I mean even scooter succumbed to the power of the dark side...
Old 02-21-2006, 01:42 AM   #6
infinitexsound
my bad yeah it is.... thanks maeda... but id still totally hack that TB flange off and run a better TB more simple then running one with a maf....
something like this
http://www.rossmachineracing.com/uni_intakeparts.html
and call it a day...
Old 02-21-2006, 01:49 AM   #7
driftkid316
cause the power ill be putting out should be enough me and my little corolla. i just wana try the na thing for awhile. il probably build another motor for turbo way later on.
Old 02-21-2006, 01:55 AM   #8
Maeda
Maeda's Avatar
Really?
With ITBs, some head work, cams, headers, exhaust and a standalone! I don't think scooter made more then 175 RWHP
You don't fully understand the full power darkside.
T3 + Mani + SR injectors + Pump + Safc + Sidemount = hello 200 RWHP
Old 02-21-2006, 03:15 AM   #9
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
boring the TB will do nothing unless you bore the intake plenum i suggest you forget ka na and piece together a turbo kit... it'll be difficult and cost you money but the na set up you speak of is expensive (machine work and balanced crank = $$$$)... if you are set on having high comp then i'm told the best way to do it is SOHC pistons (you had that right), 91 spec cams, z32 fuel filter, exhaust, intake, and if you wanna spend the money a good port polishing job on the head wouldnt hurt...
did you say your putting this in a corolla? i was confused about that statement
trust me dude turbo is way better
TougeSR20Kid is offline   Reply With Quote
Old 02-21-2006, 03:53 AM   #10
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
i think hes putting it in a a86 in that case 160 hp is very good. lots of torque too. good luck.
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 02-21-2006, 06:13 AM   #11
neverlift
neverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymore
do both sides of t/b and intake plenum matched but don't over do it you could use a brake cylinder hone depending on the size and cutting stones you use
derp derp
neverlift is offline   Reply With Quote
Old 02-21-2006, 08:52 AM   #12
sxse240
sxse240 is on a distinguished road
If you're going to bore the throttle body, I'd go here: http://www.maxbore.com
sxse240 is offline   Reply With Quote
Old 02-21-2006, 09:11 AM   #13
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Thats the guy I plan on using, going to put a KA24E throttle body bored put onto my CA. A guy in nico got his KA throttle body done and posted results pictures. top notch
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 02-21-2006, 10:44 AM   #14
sdtouge
sdtouge can only hope to improve
some guys are just into n/a
my last 240 was turbo and i dont really like it right now. turbos blow, its expensive, its messy, shit blows off like piping etc, and mine was a simple stock manifold, semi stock piping and upgraded smic w/ gt28r.... anyways turbo=alot of work and alot of mess oil everywhere.
sdtouge is offline   Reply With Quote
Old 02-21-2006, 02:19 PM   #15
highkck
highkck is making a name for him/her selfhighkck is making a name for him/her self
KA Here is the down low on the TB boring.
I had Maxbore.com do my KA24DE TB. The gains are nice. I felt alot on the A$$ dyno. The Torque increased. Its recommended whether your Turboed or NA. THe bottom plenum on the manifold has about a 1-2mm that can be bored out. I plan on boring mine out after I pull the manifold to replace the headgasket during turbo install. Ive inclosed pictures of what maxbore does. He'll take the stock TB (63mm) and bore it to 70mm give are take 1mm. Here is a post and pictures on nicoclub. I did a write up on this mod.
http://forums.nicoclub.com/zerothread?id=143227
And for the people that think the MAF is a limiting factor that will be going away when Im boosted so its really not an issue.
Zack "95 240sx SE"
highkck is offline   Reply With Quote
Old 02-21-2006, 02:41 PM   #16
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Cool, I think I might send my RB20 TB and manifold to him for boring (and CLEANING!). Does he send you the matching gasket back with the TB?
MELLO*SOS is offline   Reply With Quote
Old 02-21-2006, 06:09 PM   #17
highkck
Send him a nissan gasket so he can match it and send it back to you. Other wise he will just take it to the max of the equipment.
Zack "95 240sx SE"
Old 02-21-2006, 06:10 PM   #18
infinitexsound
u dont need ITB to get big NA power... i know so... u can run something similar to what i posted.. and its just about the same as running itb... but get rid of the ugly ass MAF...
Old 02-22-2006, 02:15 AM   #19
Maeda
Maeda's Avatar
+1 for getting rid of ugly MAFs.
