Old 03-04-2006, 10:06 PM   #1
King 240
Banned from the Marketplace
King 240's Avatar
King 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-knownKing 240 is making his/her stupidity well-known
Question on SR cooling and AC
Ok I know that if you have AC on the SR that having the condensor infront of the Rad and behind the FMIC, will provide alot of air flow restriction.
My initial question is why, besides that reason, do the SRs run hot with AC?
To help on the condensor blockage problem, do you think it would be efficient to use a condensor mounted to the side of the FMIC, similar to a oil cooler but have if run the AC? That way it will be cooled and also there won't be the large condensor blocking the Rad.
Just a thought I had, seeing as I'm running AC on my SR.
King 240 is offline   Reply With Quote
Old 03-04-2006, 10:09 PM   #2
s14alex
s14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of lights14alex is a glorious beacon of light
s14alex is offline   Reply With Quote
Old 03-04-2006, 10:10 PM   #3
King 240
King 240's Avatar
lol, well I have Flex-lite fans...could it be possible that the motor isn't running as strong as it used to, thus not cooling very well?
Old 03-04-2006, 10:22 PM   #4
hairy519
hairy519 is an unknown quantity at this point
besides flex a light fans what else do u have for ur cooling system???????
hairy519 is offline   Reply With Quote
Old 03-04-2006, 10:24 PM   #5
hairy519
Originally Posted by s14alex
bitchin fans i've got that in my s14 they do hell of a job! lol
Old 03-04-2006, 10:10 PM   #6
datboibrad
datboibrad can only hope to improve
you need help steve. seriously
datboibrad is offline   Reply With Quote
Old 03-04-2006, 11:35 PM   #7
SoSideways
SoSideways's Avatar
Your best bet is to either cut hole(s) into your front bumper to allow more airflow to go through into your cooling system.
After cutting the front bumper on my car, my temp stayed stable at around 195 degrees F. Before, it was climbing over 200 degrees, and I wasn't very comfortable with that.
Old 03-05-2006, 02:31 PM   #8
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
or get an F'n Koyo like i did! my stock rad was fine til i installed AC. its would get hot after about 15+min of driving and i was running altima fans and motor fan.
yea i couldnt live without AC much longer in hot ass texas!!!
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 03-05-2006, 08:00 PM   #9
hipro
hipro is an unknown quantity at this point
For our SR's with A/C, we have kept the stock mechanical fan and added a single electric, which has worked well even with a big front mount intercooler.
hipro is offline   Reply With Quote
Old 03-05-2006, 08:42 PM   #10
SoSideways
SoSideways's Avatar
Well, I don't have any radiator panels (top or bottom), and I only have the clutch fan with shroud. Shit, the shroud isn't even bolted on or anything. It's ziped tied on, and I had to cut the shroud to clear the AC drier. So there are mad gaps everywhere around the shroud.
Only thing I think saved me, was the fact that I ran Redline water wetter (the whole bottle) and ran 85/15 or 90/10 water/coolant mixture.
And the hole I cut on the front bumper.
Now it's like 100% water + water wetter.
Don't worry, will add some coolant soon.
Old 03-06-2006, 01:30 AM   #11
KOUKI_VERS13
Trader Rating: (18)
KOUKI_VERS13 is an unknown quantity at this point
Feedback Score: 18 reviews
what kind of fans are you guys using for your condensers?, stock?, aftermarket?, which brand? My condenser fan motor went out, so im thinking of whether i should "rebuild" it and buy a new motor, or go with Greddy's 9 inch puller fan..
KOUKI_VERS13 is offline   Reply With Quote
Old 03-06-2006, 01:10 PM   #12
Muzzy
Muzzy's Avatar
i jus have the motor fan with dual altima fans onteh rad
lemme have a dollar
Old 03-06-2006, 05:38 PM   #13
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
are you running a/c? also do you have the a/c pusher fan? got any pix of your set up?
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 03-06-2006, 02:27 PM   #14
SoSideways
SoSideways's Avatar
Just the clutch fan, no other fans, but I do have the shroud.
