![]() Ok so I got an electronic boost gauge from greddy, 52mm, non peak hold, and I got the wiring done on it, but I dont have instructions on how to hook up the vacums for the sensor. I though I just needed to run a line from the intake manifold to it, but a friend is telling me that I need to use a Y, with one line coming from the intake manifold, and the other one teed off the fuel pressure regulator line, the both merge through the Y and then connect to the sensor. Is this the right procedure?
Thanks
I'm gonna show you that a mobile suit has its limits my friend, especially when you are up against the Red Comet |
No more nissan.
![]() Join Date: Jan 2003
Its regulator. and they say to use that vacuum source for the most accuracey..
but you can really just take vacuum from any nipple on the manifold. You will be hard pressed to notice much of a difference in the readings.
![]() Join Date: May 2003
Yes on the intake manifold or before the throttle body basically. You can T-off of any vacuum line but if you have an extra nipple, just go direct to the intake manifold.
- Jay ![]() WTB: Nothing at the moment. LEWL WTS: Everything sold, thanks folks! |
#15 |
No more nissan.
Then go buy a T available at any hardware store.
Cut an existing vacuum line, insert the T and go off the other end of the T to your boost gauge. Done and done. Make sure the fitment is tight or you'll get a vacuum leak.
