Old 06-12-2006, 07:55 PM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
delay in steering input. How to get rid of it?
About three weeks ago I put HICAS front steering rack, aluminium steering bushing, and new polyurethane steering rack bushings in my car. First 2 days, the car handling was like go-cart. Then I began to get some lag in steering input.
So everytime before I drove, I turned steering wheel lock to lock 5 to 10 times to bleed air off PS system. Doing this got rid of the lag or reduced it a lot but the lag come back after 10 minutes of driving.
I installed HICAS rack on my car because people on this forum said HICAS would get rid of the lag in steering input. Now I still find lag in steering input.
I really want to get rid of free play on my steering wheel and get that go-cart feel back. What should I do? Do you or anyone know what is going on?
jafero is offline   Reply With Quote
Old 06-13-2006, 12:13 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Dunno... sounds like you may be having power steering issues. You shouldn't need to 'bleed air off PS system' everytime to drive. I would start there.
Old 06-13-2006, 03:35 PM   #3
jafero
PS works fine without bleeding air off everytime I drive.
Just that when I turn the steering wheel, the car follows only after the steering input, not at the same time with the steering input.
Old 06-13-2006, 04:00 PM   #4
AntiVtec
AntiVtec is an unknown quantity at this point
might be your rack. I had to change mine because of the wheel play and it helped alot. there is still a little play but im not running power steering so its normal for me. good luck
AntiVtec is offline   Reply With Quote
Old 06-28-2006, 01:12 AM   #5
darklynoon
darklynoon is an unknown quantity at this point
Send a message via Yahoo to darklynoon
you DO need to bleed a HICAS system...two bleeder screws, one on right side, one on left side. They are different. Turn all the way to the right (with the car running), n bleed the right side one,, then to the left all the way, n bleed the left one. repeat till no more air bubbles, just like u blead brakes...kinda sorta. since you dont actually have a hicas system, not sure if this will do any good, but it's worth a shot
I DON'T DRIFT, BEOTCH!!! It's called a burnout, into a fishtail, ending in a powerslide...
darklynoon is offline   Reply With Quote
Old 06-28-2006, 01:03 PM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
steering shaft bushing
Old 06-28-2006, 07:03 PM   #7
kandyflip445
kandyflip445's Avatar
Maybe even sway bar bushings.
My 240 vBgarage
Old 06-28-2006, 09:17 PM   #8
McRussellPants
Run a cooler on your PS.
McRussellPants is offline   Reply With Quote
