Old 06-22-2006, 07:26 AM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
overfilling the power steering fluid reservoir
I had topped power steering fluid reservoir for a few week and recently I learned that overfilling the reservoir is no no. The steering worked fine without noise. Only thing I was concerned was that control input had some delay.
What could overfilling the power steering fluid reservoir result in?
jafero is offline   Reply With Quote
Old 06-22-2006, 10:02 AM   #2
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
OMG....your car's gonna blow up!!
nah, i've done that before and never had any problems. it could cause problems but i haven't faced any.
drifter808 is offline   Reply With Quote
Old 06-22-2006, 10:28 AM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
take some out if you haven't already. The min and max are there for a reason.
Old 06-22-2006, 01:26 PM   #4
Dream240
Dream240's Avatar
The problem with overfilling is that you will create excessive pressure in the system, which will eventually blow the seals on the rack & pinion. This problem will happen with any fluid based system that doesn't have a vent or overfilled relief of some sort. It's really hard to overfill a manual tranny or rear diff due to the fact that fluid above the fill plug will just pour out.
If you've got it overfilled, then just get a turkey baster and suck some out.
Also you mentioned a lag in the steering response....just a question but did you do some kind of maintenance on your steering system to warrant a fluid refill? If you were just topping of a low system then you might want to look into replacing both return hoses. They are very common for going bad at the clamps and seeping fluid out. You have to get one of them from the dealer but the other you can just replace with a piece of oil cooler line cut to fit. Look into it....
Also make sure you bleed the system after any fluid drain....otherwise your steering response will be non-existant. Hope this helps.
Old 06-22-2006, 01:38 PM   #5
aznpoopy
aznpoopy's Avatar
yeah... if you're dirty like me just keep dipping your finger in the resovoir and whipping the contents at your friend.
turkey baster works well too.
Old 06-22-2006, 02:45 PM   #6
aznrib
aznrib is making a name for him/her selfaznrib is making a name for him/her selfaznrib is making a name for him/her self
hahah that's awsome
i think i have the same problem. it's leaking from the end of the hose. The thing is if you get the hose from the dealer it's lik 200 something dollars.
aznrib is offline   Reply With Quote
Old 06-22-2006, 03:42 PM   #7
Dream240
Dream240's Avatar
Originally Posted by aznrib
hahah that's awsome
No no....not the high pressure hose. I'm talking about the two return hoses. They are just simply rubber hoses, oil cooler hose specifically. The custom bent hose is about 25 bucks. And the other hose can be replaced with about 18" of oil cooler hose from Kragen. can't remember what the diameter was though.
I've done this on both of my 240s and it fixed the problem. Oh also get new clamps, those stock clamps are what lead to hose failure.
Old 06-22-2006, 05:37 PM   #8
s14slide
s14slide's Avatar
s14slide is an unknown quantity at this point
Send a message via AIM to s14slide
Dude, seriously. Overfilling the resevior will do nothing but make a mess. Shit, just at normal fill level, I get the resevior to blow shit all over the place when I do gymkhana, but that seems to be only common on JDM s13's. And even if you let it drain all the way, what the hell do you need to bleed it for? It's a looping system, the fluid is always flowing as long as the pump is spinning. Fill the resevior, cycle wheel. Repeat till it stops sucking down fluid and fills up. And for pressure relief, it'll bleed past the seal for the cap before anything else. That seal has no pressure hold at all, and it'll leak there first.
= My day
s14slide is offline   Reply With Quote
Old 06-22-2006, 07:16 PM   #9
jafero
Thanks for your advices, guys.
Dream240, I put HICAS front rack a few weeks ago and did complete bleed.
Haven't had a leak in the seals.
I took some of the fluid out and now fluid level is within the FSM's spec.
Handling got sharper but not the best. Still feels mushy. Does air pockets somewhere inside the PS system created by the excess fluid foaming delay the input made from steering wheel?
I will do complete bleed again.
Old 06-22-2006, 08:24 PM   #10
chmercer
chmercer's Avatar
to bleed ps just jack the front of the car up and turn the wheels left and right a lot. easy as pie. if your handling is messed up id look somwhere besides an overfilled power steering resivor. overfilling that thing will do absolutley nothing, all it will do is get power steering fluid in your engine bay after it warms up. s14slide covered it pretty well.
chmercer is offline   Reply With Quote
Old 06-23-2006, 09:17 AM   #11
jafero
I just found that too much fluid cause foaming in the PS system and induces air into the system. Doesn't air in the PS create steering input delay?
Old 06-23-2006, 09:32 AM   #12
chmercer
chmercer's Avatar
yeah if you have air in the ps fluid the pump isnt gonna work but its not a closed loop system, resivor isnt even pressurised, so its super easy to bleed
Old 06-23-2006, 10:24 AM   #13
pr240sx
pr240sx is an unknown quantity at this point
Quite a while ago, because power steering fluid overfill, it started a small fire and burn my ignition resistor.
Hydraulic fluid is flamable under heat so be sure and drain some to be sure.
pr240sx is offline   Reply With Quote
Old 06-28-2006, 12:40 AM   #14
darklynoon
darklynoon is an unknown quantity at this point
Send a message via Yahoo to darklynoon
ummm....
you are using dexron II/III auto tranny fluid, not power steering fluid right?
BTW, i just had my high pressure hose burst, so i'm about to replace it with an autozone model (not the best choice, but my only choice) its got the banjo bolt connector for the pump, but the bottom connector part, a metal rectangular block with a threaded hole on the side not attached to the presseure hose, where i assume it is supposed to connect to the high pressure tube (that actually bridges the gap from the hose to the rack and pinion) is drasticaly different. anyone ever run into this before?
I DON'T DRIFT, BEOTCH!!! It's called a burnout, into a fishtail, ending in a powerslide...
darklynoon is offline   Reply With Quote
Old 06-28-2006, 07:31 AM   #15
pr240sx
Get your hose redone.
Cheaper and better than AutoCrap one.
Any truck autoparts or farm equipment store can do it.
