Old 07-18-2006, 11:22 PM   #1
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Blowing fuse when turning on side markers (1 click) in S14
I have a s14 Kouki and I keep blowing fuses when I click 1x for the sidemarkers to turn on, along with the gauge cluster, clock backlight, and the control illumination. I've read previous posts to check grounds, which I have, and wires that MAY have been shorted which I also have. My question is has there been any sort of known issue that might've been causing this? Thanks for any reply.
mmdb is offline   Reply With Quote
Old 07-18-2006, 11:28 PM   #2
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
I got a problem something similar to what you got but I blow Fuses when ever I try to switch to Highbeams but the thing is the left headlamp is the only one the eats the 15amp fuse. There is an open wire or something that is not making the right connection with you. Check you wires I bet there is one that is open and shit so just tape it up with black electrical tape and hopefully that might clear you're case with the mysterious fuse blowing.
Ricks15 is offline   Reply With Quote
Old 07-19-2006, 01:55 AM   #3
2tone240
2tone240 is making a name for him/her self2tone240 is making a name for him/her self
check for any pinched wires. if you crashed your car, took off your bumpers, or done anything that could have gotten the wires pinched. if it's pinched like on the bumper support or something it could be grounding itself out.
2tone240 is offline   Reply With Quote
Old 07-19-2006, 05:58 AM   #4
g6civcx
g6civcx's Avatar
Other than doing what you did, check the main engine harness underneath the front fender. Sometimes the suspension grounds out and cuts that harness.
Old 07-19-2006, 10:03 AM   #5
Yuri
Ghost of Zilvia past
Yuri's Avatar
Check for pinched or shorting wires. When I crashed at irwindale, I had the same problem. It turned out to be the license plate wires were pinched and shorting out.
Yuri is offline   Reply With Quote
