Old 07-31-2006, 12:29 AM   #1
stevejames3
stevejames3 is making a name for him/her selfstevejames3 is making a name for him/her self
Send a message via AIM to stevejames3 Send a message via MSN to stevejames3
HUGE oil leak problem! help please
ok. lets start off with the basic info, i have a 92 240 with a redtop sr20det.
Now, the problem.
i just got the sr swap running today, which by the way it started up first turn of the key like a champ! anyways, after i started it my friend told me to shut her down. then he said i must have been missing a gallery plug. so we tracked it down and plugged it. then we relized there was more, mostly under the intake manifold(1, maybe 2) and the front cover had alot of oil on it(which i think i tracked down to the timing chain tensioner). my question is, can someone list specific places on the block with these gallery plugs so i can check them all or any place vulnerable to a problem of this sort. thanks for any help.
stevejames3 is offline   Reply With Quote
Old 07-31-2006, 07:52 AM   #2
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
hmm, I say clean all the oil off, put some dye in it, then see where it's coming from. That is really the easiest way IMO. u can buy a kit from a parts store. It includes the dye and the black light (I think it's a black light). Good luck
shayrgob240 is offline   Reply With Quote
Old 07-31-2006, 03:36 PM   #3
slider2828
slider2828's Avatar
Yah clean it ALL off to shine and then check for leaks... Easiest way. A lot of places can leak....
Old 08-01-2006, 04:38 AM   #4
stevejames3
got a block leak tester and i will be checking today or tomorrow. from the info i gather looks like front main seal might be bad, also the timing belt tensioner is leaking. any idea if i can just take that off put a new gasket on and put it back in without messing up the timing at all, i dred having to do timing again.
