Old 08-01-2006, 05:35 PM   #1
slider2828
slider2828's Avatar
Do I need to resurface my Flywheel?
Hey Guys:
The flywheel is like 6 months old. It is a fidanza flywheel and it maybe has like 6k miles on it. How do I check if I need to replace the face of the flywheel or not?
Has anyone ever replaced the face on it? If so, was it hard and were there any instructions included in the face?
-Ken
Old 08-01-2006, 05:42 PM   #2
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
Originally Posted by slider2828
Hey Guys:
-Ken
Hot spots, cracks or warpage. If all of that is ok, then its fine. With 6k miles on it, unless you were slipping the clutch a lot it should be fine.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 08-02-2006, 09:44 AM   #3
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
shouldn't the flywheel be resurfaced every time a new clutch is put in?
There are hotspots on my TODA flywheel. Is that a negative thing?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 08-02-2006, 09:46 AM   #4
Phlip
Yes, I look like that
Phlip's Avatar
I suggest resurfacing, do it once the right way, instead of doing it wrong once only to have to do it all over.
Weirdo
And I write too!
Old 08-02-2006, 10:44 AM   #5
slider2828
slider2828's Avatar
Hot spots usually means you have dropped the clutch more than slipping the clutch if iirc, its just normal but does mean you do need to get the flywheel resurfaced.
Old 08-02-2006, 10:52 AM   #6
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
There most likely isn't a need to resurface it. Resurfacing is usually done because a flywheel wears much like a brake rotor. Over time grooves develop in the flywheel and the surface needs to machined so its all even. It also removes any warping. This allows maximum surface area contact with the friction disk, and a mating surface for the clutch to break in on.
Check the flywheel for warping with a straight edge and some feeler gauges. Then inspect the surface for gouging, grooves, and cracks. If thats all fine, take some fine grit sand paper and scuff the flywheel in a non-dirrectional pattern, then wash it with soap and water - not brake cleaner - soap and water!
Remember to replace the pilot bushing. Don't cheap out on a $1.50 piece of brass.
Hot spots are usually caused by 'dropping' the clutch. The discolored areas have been overheated and their chemical and physical properties have changed. The discolored metal now has a different friction coefficient than the rest of the flywheel. I would get the flywheel resurfaced .002" - .008" or whatever it takes to cut off the surface layer. If the hot spots are still there after surfacing, just live with them.
S13Eye is offline   Reply With Quote
Old 08-02-2006, 12:56 PM   #7
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
Any time you replace the clutch, you should resurface your flywheel. In the case of the fidanza, just buy a new face - they're like 70 bucks. I replaced mine and had no problems, it's pretty straightforward. The only problem I had was figuring out if I had 20 or 18 screw holes, because my transmission was still in the car. Turns out you have to buy both, so that problem was solved. Do you have 18 or 20? I have an extra 20 if you need it.
PhilthyS13 is offline   Reply With Quote
Old 08-02-2006, 01:26 PM   #8
aznpoopy
aznpoopy's Avatar
^ yep
you don't resurface a fidanza... you just buy a new contact plate and slap it on.
Old 08-02-2006, 02:33 PM   #9
slider2828
slider2828's Avatar
Are there any torque specs to the screws and how many screws do I need?
Old 08-31-2006, 09:51 AM   #10
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Just e-mail Fidanza.
Jung918 is offline   Reply With Quote
Old 08-31-2006, 02:59 AM   #11
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
Go DL the FSM and check, im sure its in there.
redsuns3838 is offline   Reply With Quote
