Old 09-07-2006, 06:06 PM   #1
gumaheru
gumaheru is an unknown quantity at this point
s13 Consult Port Connection Not Working ?
Alright guys,
I need some help. I have a 93 240sx hatch with a s13 blacktop swap. I was wondering how I can test the pins on the consult port to make sure that I am getting a signal. What pins should I touch and what should the voltage read? The reason being is that I bought a usb to consult port cable and I can't get it to work. I am a IT guys so I would say that I am very resourcful when working with computers. I found who they get their cables from and a developers kit for the cables. When I do an install, I can see data generated for the cable in the deveopers kit. I am not rulling out the cable all together, but I want to make sure that my port works. Appreciate the help guys.
--Jason
gumaheru is offline   Reply With Quote
Old 09-07-2006, 06:55 PM   #2
g6civcx
g6civcx's Avatar
Check your ECU wiring where the ECU plug meets the body harness. The CONSULT port may not be hooked up.
Old 09-08-2006, 12:42 AM   #3
gumaheru
I took a look and all of the wires are connected. I called the guy that I did the install and he said that he used the sr dash harness so he didn't cut anything. The most he did is added some wires. I also tested the voltage between the ignition and ground. I didn't get a signal until I turned the key to on. That much tells me that those two wires are working. How can I check the other pins voltages and what are their correct voltages. I did look through though the manual and couldn't find voltages for them and which pins to touch at the time of testing.
--Jason
Old 09-08-2006, 02:22 AM   #4
whomiked
whomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choices
whoa why would he use the sr dash harness?
whomiked is offline   Reply With Quote
Old 09-08-2006, 08:05 AM   #5
projectRDM
projectRDM's Avatar
Green, green/white, and green/black are the CONSULT port wires, TX, RX, and CLK as defined in the FSM.
99% of people who install SRs/RBs do not bother connecting the port.
Old 09-08-2006, 08:10 AM   #6
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
yea thats what im wondering. youre supposed to cut the KA connector and swap it onto the SR harness.
ladiesman8527 is offline   Reply With Quote
Old 09-08-2006, 08:14 AM   #7
Pstl_pete
Pstl_pete is a jewel in the roughPstl_pete is a jewel in the roughPstl_pete is a jewel in the roughPstl_pete is a jewel in the roughPstl_pete is a jewel in the roughPstl_pete is a jewel in the roughPstl_pete is a jewel in the rough
To be sure just cut the plug from the drivers side and solder it back in right by the ECU. Most swaps do not include the consult port wiring since they are never used. Trust me, its much easier then tracing the wires to see if they are working or not.
S14 - New SR Project
http://www.speed.academy
Pstl_pete is offline   Reply With Quote
Old 09-08-2006, 08:39 AM   #8
myzislow
myzislow's Avatar
myzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond repute
I posted a consult port wiring diagram @ www.240sxforums.com in the D.I.Y section, it will be the same for blacktop.
like prev. stated most people dont use it, but I work @ nissan so I have constant access to consult. absolutey love the data monitor!
myzislow is offline   Reply With Quote
