Old 09-12-2006, 08:42 PM   #1
ondatdryftonyte
ondatdryftonyte is on the path to ruinondatdryftonyte is on the path to ruin
tie rod setup
i have stock s14 tie rods, w/ kazama s14 ends on my s13. my question is... is that just as much angle as s13 aftermarket tie rods w/ends. or can i do more with my s14 kazama ends?
thanks
-big poppa T
"HEY theres wires sticking out of your tires, you should get those changed!!!" "THOSE???" "i've got like 3 more weeks on those!"
ondatdryftonyte is offline   Reply With Quote
Old 09-12-2006, 08:52 PM   #2
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
No that is not the same. Aftermarket ends come with spacers and more threads to give additional steering angle.
Old 09-12-2006, 10:11 PM   #3
ondatdryftonyte
wierd flybert what you said, when here i believe it says "Aftermarket ends come with spacers and MORE THREADS to give additional steering angle" idk, maybe i dont read so well?
thanks nissan4u for actual info, not just a retard trying to make people look dumb.
Old 09-12-2006, 08:54 PM   #4
Flybert
Like he said, you get additional angle from the spacers that go between the inner tie rod and the rack. Just order some spacers from splparts.com for $10 or whatever they sell for.
Old 09-12-2006, 09:10 PM   #5
ondatdryftonyte
Unhappy
sooo sad if so!!! when i compared the s13, and s14 tie rods, the s13s threads were noticeably longer than the s14s by about a pencil eraser size. i know they gave me more angle, but i want extreme angle, how do i go abouts that? if anyone has a similar tie rod setup lmk, or if your pretty knowledgable about it, post. oh and if this has been discussed before flame me, then hand me the link! lol.
thanks
DORIDORI FOSHORI
Old 09-12-2006, 09:53 PM   #6
Flybert
Did you read anything that we posted? Having more threads doens't give you more angle. Try learning to read before you try and figure out how to get more angle out of your tie rods.
Old 09-12-2006, 09:56 PM   #7
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
The small spacing provided by the spl spacers or some inner tie rods is enough. Anymore then that and your going over center. Its not the ends that give steering angle, its the part that connect to the rack that does.
Nizzan4u2nv is offline   Reply With Quote
Old 09-12-2006, 10:27 PM   #8
Nizzan4u2nv
I think he meant inners. Some inners have built spacers so you dont need the kind that spl sells.
SPL has outers with spacers for bumpsteer adjustment only but not for steering angle.
Old 09-13-2006, 12:49 AM   #9
arian23
arian23 is an unknown quantity at this point
who has better rods? tein or spl?
arian23 is offline   Reply With Quote
Old 09-13-2006, 12:56 AM   #10
Nizzan4u2nv
SPL sells oem z32 inners. Theyre beefier then stock s14. Tein are stock replacements.
Old 09-13-2006, 01:34 AM   #11
driftkid316
driftkid316 is making a name for him/her selfdriftkid316 is making a name for him/her self
Send a message via AIM to driftkid316
i got tein tie rods and kts ends. so since i got tein, this means its same as stock since theyre stock replacement? same angle as stock?
driftkid316 is offline   Reply With Quote
Old 09-13-2006, 01:21 AM   #12
dorifto-san4o8
dorifto-san4o8 will become famous soon enoughdorifto-san4o8 will become famous soon enoughdorifto-san4o8 will become famous soon enoughdorifto-san4o8 will become famous soon enough
on spl's website it says the spacers are not safe for street use. does anyone run them for daily driving? i should of jes got them anyways when i bought my inner and outter rods from spl. now i gotta take it apart again and get my car alighned. dammit!
dorifto-san4o8 is offline   Reply With Quote
Old 09-13-2006, 01:33 AM   #13
Nizzan4u2nv
Where did you see that? The only reason they probably say that is because of added bumpsteer, altered steering ratio, or the fact that you have less area threaded into the rack.
Old 09-13-2006, 01:45 AM   #14
dorifto-san4o8
does adding those spacers give you a noticeable difference while drifting?
Old 09-13-2006, 01:48 AM   #15
Flybert
Yeah, gives you a very noticeable difference.
Old 09-13-2006, 01:51 AM   #16
dorifto-san4o8
im gonna go order it right now from spl! just dreading to pay for another alighnment
Old 09-13-2006, 01:06 PM   #17
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
What's the rush to put spacers on?
I'd order the spacers and drive the car as is until I do enough suspension mods to warrant another alignment.
Old 09-13-2006, 03:42 PM   #18
Nizzan4u2nv
But, when he puts the spacers on, its gonna add toe in to whatever width the spacer is since hes spacing the tie rod away from the rack. Id just eyeball it for now.
Old 09-13-2006, 03:29 PM   #19
Flybert
Just do the alignment yourself. Measure the current length and then set it and eyeball it to see if you got it right. Eyeball measure it again until you get it right. Works for me since i run same wheels and tires front and back. I'm just waiting until I get a cage and some rear toe arms. After that it's corner weight and alignment time.
Old 09-17-2006, 08:01 PM   #20
ondatdryftonyte
so with my s14 tie rods, and kazama ends did i get more steering angle, if so, can i still get spacers, without too much spacing??? if you can get what im saying, lol
Old 09-17-2006, 08:49 PM   #21
Nizzan4u2nv
I think it already says above. You dont get more angle from tie rod ends. Only if you have a spacer between the inner tie rod and steering rack. Some aftermarket inner tie rods have a built in spacer on the part that screws into the rack. You dont have anymore angle so buy the ones from spl. Or if youre broke, get creative at home depot or something.
Old 09-17-2006, 08:58 PM   #22
ondatdryftonyte
well i dont know if this is the same question the third time, but...
is the s14 inner tie rod longer than the s13??? i have s14 tie rods on my s13
Old 09-18-2006, 01:40 AM   #23
Flybert
Why do you care if it's longer? It doesn't make a difference if it is because you have to align the car anyways which adjusts the total length of the tie rod.
