Old 09-18-2006, 09:06 PM   #1
ZenkitonS14
ZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfectionZenkitonS14 is close to perfection
s14 starter problem
1995 S14-was auto, swapped to manual now. I turn the car on and NOTHING at all happens. I have full power from the battery. the starter makes no noise at all. DOES NOTHING AT ALL. ignition switch maybe????
Email
Jake@optionimports.com
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
ZenkitonS14 is offline   Reply With Quote
Old 09-18-2006, 09:08 PM   #2
Dousan_PG
Dousan_PG's Avatar
fsm is your friend
Aaron
Pink GodziRa
Old 09-18-2006, 09:12 PM   #3
ZenkitonS14
Originally Posted by Dousan_PG
fsm is your friend
sorry if its obvious, but whats FSM?
Email
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
Old 09-18-2006, 09:11 PM   #4
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
no power at all?
does that mean your car has no power OR do you mean that when you try and crank it the car jstu wont start?
did you jumper the two wires together to clutch cancel safty switch? you ahve to do tht for auto to manual swaps
rim_bender is offline   Reply With Quote
Old 09-18-2006, 09:16 PM   #5
ZenkitonS14
Originally Posted by rim_bender
no power at all?
yea, did the two wires, sorry for got to mention, its ran since the swap, just outta nowhere today it started acting up. Another thing, ever since i went to the track last weekend when i turn the car off and try to take the key out i have to wiggle the key around to get it to get free, thats y i think it may be the ignition switch?????
Email
[email protected]
Tel: 626-581-7200
Fax: 626-330-3155
275 S 3rd Ave. #2
La Puente, CA 91746
Old 09-18-2006, 09:16 PM   #6
rim_bender
factory service manual
