Old 10-22-2006, 10:26 PM   #1
alpalwal1
alpalwal1 is an unknown quantity at this point
Longer 5th gear or final drive?
I drive a lot on the freeway in my 240 and I hate the short 5th gear.... 1-4 is cool, but I really dont like being at like 3k at 67 mph.
What are the options for either longer 5th gears or differentials? I've got the 6 bolt axles and don't want to replace them if i don't have to.
alpalwal1 is offline   Reply With Quote
Old 10-22-2006, 10:30 PM   #2
!Zar!
!Zar!'s Avatar
You could get a lower ratio ring gear, but that will lower your accel speeds. For that option you are spending about $500 for a ring gear.
Other than that, all you can do is deal with it.
Old 10-22-2006, 10:51 PM   #3
alpalwal1
how about just a different diff? any ones with longer legs that the 240 that bolt in?
Old 10-22-2006, 10:56 PM   #4
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
The definite easiest solution would be larger wheels/tires. The r&p is the gear part of the differential. That is what you replace, not the entire unit. Search son
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 10-23-2006, 01:33 AM   #5
R34SKYLINE
R34SKYLINE is an unknown quantity at this point
94 S13
4.083
49/12
R200(v)
96 Z32 Na
4.083
49/12
R200v
94 J30
3.916
47/12
R200v
99 Q45
3.692
48/13
R200v
96 Z32 Tt
3.692
48/13
R230v
94 Q45
3.538
46/13
R200v
R34SKYLINE is offline   Reply With Quote
Old 10-25-2006, 08:44 PM   #6
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
I'd ge tthe Q45
Review Thread
bardabe is offline   Reply With Quote
Old 10-25-2006, 08:50 PM   #7
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
A Q45 pumpkin( larger driveshaft flange) will not bolt into our cars, nor a Z32TT. You would have to yank the internals and install them in your pumpkin
New Video
Buy my mounts!
Old 10-25-2006, 10:03 PM   #8
bardabe
bardabe's Avatar
That's what makes it fun DO IT!
Review Thread
Old 10-26-2006, 12:20 AM   #9
alpalwal1
alrigt... so the z32 and q45 internals will fit in my diff though?
Old 10-26-2006, 12:31 AM   #10
drift freaq
no thats not exactly what I meant to say. Basically any R200 internals including q45 , M30 ring but not the pinion, will fit. I added the fact that the Z32TT would not fit because its a R230v, its internals are larger. To tell you the truth most of this information is already available in the archives and faq section between a faq I wrote and 3 other ones.
New Video
Buy my mounts!
Old 10-26-2006, 12:25 AM   #11
McRussellPants
no.
R200 is different than R230, the numbers are ring gear diameters.
IIRC its possible get the whole 230 Rear end and axles into an S-chassis.
your car is gonna be so piss slow with a 3.6 gear though
McRussellPants is offline   Reply With Quote
Old 10-26-2006, 12:31 AM   #12
mrmephistopheles
mrmephistopheles's Avatar
I'm going to be getting a S15 Spec-R MT final drive. 3.69
My goal is for high MPG via low RPM cruising.
It will not be much fun to fart around in anymore.
Looks a little something like this:
Originally Posted by PHLIP
Old 10-26-2006, 08:01 AM   #13
sxse240
sxse240 is on a distinguished road
Try my gear ratio calculator spreadsheet.
sxse240 is offline   Reply With Quote
Old 10-26-2006, 09:29 AM   #14
Dousan_PG
Dousan_PG's Avatar
u got one kevin?!?!
Aaron
Pink GodziRa
Old 10-26-2006, 11:51 AM   #15
R34SKYLINE
Is there a way I could figure which gear ratio I have if I know my car gets I believe 79mph @ 3000rpm my car is automatic with a JDM 180SX VLSD and my wheel and tire size are:
18" wheels with 225/40/18
From that info could one find out what final gear ratio I have even though I got an auto tranny?
P.S. I dont have Excel just the viwer but I do have Microsoft Works Suite 2006 and I was able to open it with Microsoft Works Spreadsheet and I can make changes and it does the recalculating automatically to .......
Old 10-26-2006, 12:56 PM   #16
R34SKYLINE
I figured it out, pretty cool shit:
KA24DE A/T
KA24DE M/T
