Old 11-22-2006, 01:14 AM   #1
roboo7
roboo7 is an unknown quantity at this point
Window Conversion??
s13-240sx in good condition are hard to come by around my neighborhood. so when i was lucky enough to buy one in good enough condition i jumped at the change. the only thing is the car is manual windows, locks and mirrors. i dont know if im gonna be comfortable with that. so i was just wondering if it would be too much work to swap the manual door set with a power door set. is it just a swap in swap out type thing or do you have to get new electronics? i know to convert power mirrors you have to get a center console switch. what else is involved? has anyone else done this? thanks for any input i appreciate it.
btw. its a '89 240sx.
roboo7 is offline   Reply With Quote
Old 11-22-2006, 02:31 AM   #2
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
yep i did it like 2 weeks ago, its just swap in and out.
All you need is:
- 2x Window rail with motor
- 2x Door Power Harness
- 2x control switch
Just rip out your old door harness, and unplug it (its near the fuses in the drivers side) Your new harness will have additional connectors, dont worry cuz your car has the plugs for them. Find them, plug in all connectors and control switch. Install new window rail,bolt window to the rail, turn key to "ON" test it.
Then your finished
projekt_s13 is offline   Reply With Quote
Old 11-22-2006, 02:53 AM   #3
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
^You make it sound sooo easy.
TipStylez is offline   Reply With Quote
Old 11-22-2006, 03:06 AM   #4
projekt_s13
lol its is, it only took me like 45 min to 1 hour. The hard part is puting in the new door harnesses.
Old 11-22-2006, 08:29 AM   #5
projectRDM
projectRDM's Avatar
You must have gotten lucky, every base model S13 I've stripped is not prewired for locks, windows, or mirrors.
Old 11-22-2006, 08:52 PM   #6
projekt_s13
wow forreal? I thought since mine had them then all base models had them.
oh well.
Old 11-22-2006, 09:13 PM   #7
roboo7
well i hope my hatch has wire preinstalled. if not, it might take me more than an hour to convert manual to power windows. btw projekt_s13 what were the options your coupe came with?
Old 11-22-2006, 09:20 PM   #8
projekt_s13
umm... cruise control, sunroof, analog cluster, it was a 91 BTW.
Old 11-22-2006, 09:23 PM   #9
roboo7
mines is a hatch with cruise control and no sunroof. did you convert the car into power locks and power mirrors also?
Old 11-22-2006, 09:28 PM   #10
TipStylez
Well...im guessing since you had the model with a few options.
Nissan made two diffrent harnesses.
One, with no options.
The other, with all the options. Then they can just hook up stuff and install it if the buyer wanted one or all of the options.
Makes sense to me, since its a cheap way to save money.
Just like when you do a 5speed conversion, all the mounting points are there for the slave, you just gotta drill it ect.
Old 11-22-2006, 09:29 PM   #11
TipStylez
Old 11-22-2006, 09:52 PM   #12
HyperTek
ebay...aftermarket power window kits and door locks..
I got Spal. good quality.. my only problem was having to re-solder the contact leads on the window motor itself
Keep it Classy
Old 11-22-2006, 10:24 PM   #13
projekt_s13
i did convert power door locks, but i didnt get to do the power mirrors since i sold the car like 2 days ago.
