Old 12-13-2006, 03:24 PM   #1
thejapino
thejapino's Avatar
thejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfection
Question about axle nut size? S13
Hey folks, off the top of your heads, what size socket would I need to remove the nuts holding the rear axles in place at the hub? Im thinking 30mm. Am I wrong? Your help is appreciated!
thejapino is offline   Reply With Quote
Old 12-13-2006, 03:28 PM   #2
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
I think its 32mm.
Best thing to do would be to search to confirm though. Was over a year ago since I removed 'em for my 5-lug but you can find the answer here. Its been covered before.
Don't forget the cotter pins... unless that's just for the fronts.
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 12-13-2006, 03:48 PM   #3
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
26mm front/ 32mm rear...oh shoot is it 36mm...well I did look at the FSM and it doesn't say
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 12-13-2006, 03:44 PM   #4
Flybert
36mm
a;dslkfjasd;fljkas;f
Old 12-13-2006, 03:56 PM   #5
Flybert
36mm 36mm 36mm
Old 12-13-2006, 04:54 PM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
36MM.
Kinda big.
had to swap out my axles, and i've still got the socket.
Did i mention 36MM?
SochBAT is offline   Reply With Quote
Old 12-13-2006, 07:52 PM   #7
SaskS14
SaskS14 is making a name for him/her selfSaskS14 is making a name for him/her self
S13 30mm Front and 36mm Rear
S14 32mm Front and 36mm Rear
1995 Zenki S14
I <3 s-chassis'
SaskS14 is offline   Reply With Quote
Old 12-13-2006, 09:24 PM   #8
thejapino
thejapino's Avatar
36mm for the rear! Thanks folks! Right on for the quick reply. I didn't want to buy all these axle sockets and then have to go back to the store to return some! Thanks again!
Lock
lok
loc
lock
Old 12-14-2006, 11:49 PM   #9
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
yup 36 is it. I would know, i had to change sochbats axles myself! You fail SOCHBAT!!!
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 12-15-2006, 12:29 AM   #10
Kahl
Kahl is an unknown quantity at this point
if you can't get a 36mm use "1 inch 7/16", might help you guys with imperial stuff.
Kahl is offline   Reply With Quote
