Old 01-09-2007, 02:11 PM   #1
eastcoastS14
eastcoastS14's Avatar
I need help
ok so i am recirculating my hks bov wasnt really 100% sure on the correct way to do this, called a shop and they said for them to do it they would have to basically weld a piece into the intake like an adapter and run a hose between the bov and that adapter(bov is mounted on the cold pipe). Is there a way to recirc without having an adapter welded on? i dont know how to weld and dont want to spend the money if i dont have to. i was thinking that i could just drill a hole somewhere on the intake or hot pipe and use some fittings to hold it in place would that work?? flame if you have to and just let me know if theres a way to do this not involving welding pics of your set up would help thanks
eastcoastS14 is offline   Reply With Quote
Old 01-09-2007, 02:23 PM   #2
steve shadows
steve shadows's Avatar
there should be an adapter for sale on ebay etc.
Like Me on FaceBook !
Old 01-09-2007, 02:30 PM   #3
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
I think you could probably rig something up with a part like this:
Try searching around for "blow off adapter"..
You'd have to cut your intake pipe between the MAF and the turbo then splice this piece in with couplers, but it would probably do the trick.
MELLO*SOS is offline   Reply With Quote
Old 01-09-2007, 02:58 PM   #4
Drakon
Drakon is an unknown quantity at this point
If you use the stock SR intake pipe it has the hole there for you allready. but you didn't say what car so this may or may not help
*image exceeds forum limits*
- Moderation
Drakon is offline   Reply With Quote
Old 01-09-2007, 03:16 PM   #5
eastcoastS14
^^ yeah sorry s14 with an sr20 intake is custom piping tho i think i might just try one of those ebay adapters
