![]() Join Date: Dec 2006
What Do yall Think
This is the list of mods I have right now,
SR20DET Red Top HKS super sequential blow off valve 255 Walbro fuel pump 550 drop in fuel injectors 300zx MAF stage 3 Greddy intercooler 2005 Greddy turbo timer 2005 Greddy boost controller Tein springs KYB AGX shocks Full Greddy piping Boost gauge Big face Tachometer(taken off of dash!) Full custom 3 1/2 '' T5 exhaust Magna Tubular Manifold Electo-lite radiator fan S13 silvia front end clip S13 aero front bumper S13 3 projector headlights Super Advan racing rims kumo tires front and back strut bars This is the list of mods that I'm gonna do in the shop Engine parts HKS step 2 264* cams - Comp Cams valvesprings - A'pexi 1.1mm headgasket - Rocker Arm stoppers - ARP Headstuds - Garret GT2871R turbo - 3" turbo outlet - New exhaust mani gaskets - Stainless turbo lines - Oil Catch can - Fuel and Management AEM EMS w/ UEGO Sensors (3 bar map, IAT) 740cc injectors -nismo Can anybody think of anything else I might need |
Its a tech question, because is there anything yall can think of that might make the car safe for under high rev conditions. I tried to think of anything else I needed, but wanted to know because I'm just getting into the Nissan Scene. Have been use to turbo cars, such as GSX, and turbo honda's, but wanted something new. Anybody have anything else I might need
![]() Join Date: Apr 2003
judging that you turbo'd your previous cars "safely", then you would've made the precautions to make the SR "safe" to rev. ras/valve springs/cams, etc, are all good, but SR's aren't known to make power at such a high rpm anyway.
Pignose, biaaatch. |
well thats why I wanted to ask all of yall because honestly I don't have any exp with Nissans but I'm sure if u take the proper precautions, and do it the right way before getting on it, it should be ok. When u say high RPM anyway, how much is that 8k-8500? I've gathered alot of info on what I thought were good builds of the SR and thats how I came up with that set up just wantin to c what ya thought, and also if I needed anything else. Also are the Greddy intake manifolds pretty good, I've heard both sides, and if they are, r they worth the money
#9 | |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
#10 | |
If you want to rev this thing to 8k+ I would go with a solid lifter setup. The hydraulic lifters just can't keep up at those high rpms. mattback has had some pretty good luck with his setup that he made. The only downside to this is that you have to check them often. If you do go this route though i would suggest going with the .086a/r 2871r and also throwing in a greddy manifold or topspeed mani for alot cheaper. A 272* exhaust cam would boost the top end power a bit too. Should make some pretty good high rpm power like that. And ofcourse as others said, with this extra power the cooling system needs to be in check too. |
upgraded radiator maybe?
not sure what piping's what, but I'm assuming you have everything larger from the turbo elbow all the way to exhaust (like no stock cat) better question is, what do you plan to do with the car? |
I plan for it to be a good mid to low 11'w track car, and something I can learn and use to get into drifting. I've never drifted before so am tryin to learn
a differential would help in both
same with more suspension/chassis stiffening goodies, there's a lot it's probably in your list somewhere, but more gauges would be good too, more for monitoring/preventive maintenance, water temp, oil temp/pressure... also didn't see upgraded clutch, or list what type of clutch you have, if it's like stage 1 or whatever, it'll suck otherwise, the power should be good to go, nice list |
#14 | |
Yeah.. Pictures! You must have a grip of cash to be going all out like this. Good luck, so far, it looks like you've addressed many of the issues in keeping the engine healthy. The wideband and EMS tune will definitely be a big part of the longevity of the engine. cheers, C |
#17 | |
![]() Join Date: Mar 2003
If your getting HKS Cams you should get Cam Gears also. Definatly need a bigger Radiator if you are making power to have 740cc Injectors. Koyo should be fine. What Air Filter??? not that its major but it wasn't listed. Small mantinance parts... Kevlar Belts, Samco Rad Hoses, SS lines, maybe a Greddy Pully Kit... Peace Drew
Follow on IG - KoukiTheToolBox |
#19 | |
![]() Join Date: Nov 2004
#20 |
![]() Join Date: Jun 2004
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
eh, i'd screw the cam gears
greddy manifold? yea you could with your 2871r, how much you gonna be boosting? fpr like above of course if you dont already have one. sounds about right... |
#21 |
Looks pretty damn good, man. I'd say go for some suspension and drivetrain upgrades at this point. Get yourself some nice coilovers, t/c rods, tie rod ends, rear upper control arms and traction links, and swaybars and tune it all. Get a front and rear lower tie bar and a floorpan brace and maybe cut out the rear bulkhead and x-brace it. Get a good LSD, clutch/flywheel, and an aluminum driveshaft, and you've got one of the sweetest S13's around.
#23 |
only difference i have is if your going with the HKS...get the valvtrain HKS its desiginged specifically for their cams but other than that go for it if you got it=
#24 |
![]() Join Date: Aug 2006
sard fpr with the an 6 fitting with a braided fuel line going to the fuel rail connect the line via the tomei fitting adapter spl sells it for i believe 40$ go with a 300zx fuel filter and a larger radiator tomei oil pan (greddy is good too) remote oil filter with the oil pressure and temp guages. tomei turbo elbo and greddy intake mani. i have lots of ideas in my head but i am way to tired
#25 |
oh also imo lsd's are great i have friends who ran 2 way but having to get new clutch plates for it gets expensive so we just weld the diff's now the are just as good and cheaper to do
