steering wheel stuck.
so back then, i had a nardi wheel + hkb hub installed. stupid me forgot to grease up the hub. so now it's stuck. did anyone have this problem before?? if so, what did you do to make it come off?
-robo |
First try bolting the steering wheel back on and yank real hard. Don't slam yourself in the face.
If that doesn't work, take the steering wheel back off and get a pulley puller. |
You can purchase a hub puller at pepboys. They aren't that expensive. I'd let you borrow mine but you live kdindof far.
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
#6 | |
![]() Join Date: Oct 2006
its the cheap easy way. unless u hit yourself hard enough u got a doctors bill. but try it and see if it worked u might have to have the wheel locked and turn left and right then pull and repeat. till you get it. works for me.
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Theres a spray that you buy to grease up the nut and give it a few minutes to soak and it should pop right off. i dont know the name of it...its not wd40 but you could try it :/
![]() Join Date: May 2006
Damn an Edcel post, this thread is blessed! =P
You're looking for a 'penetrating lubricant', there are a few out, but check Autozone. It's ideal to try to loosen it with the lube, and use the wheel to break it. If you have to get a hub puller, as said above, they're cheap ~
I found that, smacking the wheel at four point works great, slides right off!
I think G6 uses this method too!
#11 | |
![]() Join Date: Apr 2004
