Old 07-25-2002, 10:54 PM   #1
91s13coupe
91s13coupe is an unknown quantity at this point
the car has done this since i bought it in jan. of this year. i just installed new plugs, cap, rotor, wires and a holly anniahlator digital ignition sytem. it only does when i mash the pedal to the floor and only in the uppper rpm range from say 4500 to 6000 rpm. it just stumbles for a second and the takes off from there. it does not do it from like 3/4 throttle acceleration even when i go into the same rpm range. its an automatic 1991 coupe. i know its not the tranny slipping in case someone was going to suggest that! any ideas???
[IMG]http://www.imagestation.com/picture/sraid43/pdff9475e53f1e81e41da0332e76c32e0/fce514e2.jpg[IMG]
91s13coupe is offline   Reply With Quote
Old 07-26-2002, 01:18 AM   #2
xhdriver
xhdriver is an unknown quantity at this point
replace your fuel filter, if that doesnt work than get a new pump also.
xhdriver is offline   Reply With Quote
Old 07-26-2002, 10:48 AM   #3
xeroxed
xeroxed is an unknown quantity at this point
most 240's have a slight hesitation when mashed to the floor....it seems to accelerate faster about 5/6 of the way down from my experience
http://community.webshots.com/album/44481102XTDEdt
-89 240sx SE Coupe
xeroxed is offline   Reply With Quote
Old 07-26-2002, 11:04 AM   #4
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
mines the same way, it feels quickest about 5/6 throttle...  ive done a through tune up recently and havent left anything out.  i cant figure it out...
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 07-26-2002, 12:53 PM   #5
91s13coupe
actually i have replaced the fuel filter also right after i got the car so its been on there for 6 months. i was thinking that the problem was fuel related. its good to know that im not the only one with this same problem. if anyone figures it out for sure please let me know! thanks for all the input!
Old 07-26-2002, 08:07 PM   #6
xeroxed
you could try the injectors, but i dont necessarily think this is a problem i've drove many 240's(im in a large 240 car club here in central florida) and every one  of them has done this exact same thing....so i think its kinda just how the car is made if its only a few seconds just dont mash down the pedal next time :-D
-89 240sx SE Coupe
Old 07-27-2002, 04:35 AM   #7
phase2
phase2's Avatar
phase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of light
Make sure you gap the plugs to the KA specs, I believe is 0.045 or 0.044, or something on that end.
If it's a short stumble, it might be an ignition miss from your holly xxxx?? ignition amplifier.  I would bypass that and run stock ignitor to see if the problem persist to narrow down the possibilities.
Business Hours: Mon-Fri 10am-6pm (Pacific)
email: [email protected]
http://www.phase2motortrend.com
phase2 is offline   Reply With Quote
Old 07-27-2002, 10:03 AM   #8
91s13coupe
it doesnt do it off the line.  it did it before i put the holly system on. it its only at about maybe 4500rpm or 5500rpm and it doesnt really cut out it just kinda "hiccups" ,like there is a hole in the fuel map?
