fuel pump problem please help
alright so i took out my fuel pump fuse and was going to change the fuel pump but i didnt so i went and put the fuse back in and i go to start my car and nothing my fuel pump isnt turning on so i put a new new fuse in and still nothing help!!
thanks |
Guest
Posts: n/a
maybe you left the fuel pump harness disconnected.
if you removed a fuse and put it back in, i doubt something is wrong with the car. chances are, there is something wrong with: a) the way you put the fuse in b) where you put the fuse in c) the way you put the fuse where you put the fuse :-) |
take the fuel pump out and get the black and red wire and touch the black to (-)and red one to(+) on a good battery and it will shoot fuel out and if it dose the fuel pump is good. then
check the ecu. take you ecu out and put it on a other 240sx like yours.if the car turns on with your ecu is good. but do not put some ones ecu and put it on your car.because it mite blow. |
