Old 04-14-2007, 03:00 PM   #1
twofourty
twofourty's Avatar
twofourty will become famous soon enoughtwofourty will become famous soon enoughtwofourty will become famous soon enoughtwofourty will become famous soon enoughtwofourty will become famous soon enough
Turbo Timer (car wont shut off)
I just installed an Apex turbo timer, wired just as the instructions say. Started the car, set it for 30 seconds and started counting down but I could not remove my key and when it was done counting down it reset and started over. My car was originally automatic and did a swap to a 5spd. I was thinking this had something to do with it, but never installed a turbo timer so I am unsure. Can anyone give me any info?
twofourty is offline   Reply With Quote
Old 04-14-2007, 07:23 PM   #2
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
could not remove ur key?
YOU'RE CRAZY MAN
95zilvia is offline   Reply With Quote
Old 04-14-2007, 07:38 PM   #3
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
Tried pressing the button to remove it? And what did you do with the white wire?
TipStylez is offline   Reply With Quote
Old 04-14-2007, 07:40 PM   #4
95zilvia
sounds like
ur key is stuck
Old 04-14-2007, 08:03 PM   #5
eastcoastS14
eastcoastS14's Avatar
so your key is still in the car right now?
eastcoastS14 is offline   Reply With Quote
Old 04-14-2007, 08:58 PM   #6
spinitsidewayz
spinitsidewayz is making a name for him/her selfspinitsidewayz is making a name for him/her self
When did you do the swap? Did you wire the park release nice and secure?
I had mine electrical taped to itself and one day i was working around the console. Afterwards it wouldnt give me my key. Lazy fix, just taped it back.
Love:
89 S13 Fastback: Super stock KA24E Daily!
Hate:
89 S13 Coupe: SR20 Under the knife.
87 FC: Half Bridge Turbo Monster.
spinitsidewayz is offline   Reply With Quote
Old 04-15-2007, 12:40 AM   #7
twofourty
twofourty's Avatar
Where is this park release wire located in the car? I did not do the swap myself so I wouldn't know
Old 04-15-2007, 01:57 AM   #8
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
Im not a 100% positive but I think he's asking if you spliced the grey wire (the wire from the turbo timer that goes to the parking brake) to the wire that goes from the parking brake to the dash to tell the brake light to come on.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 04-15-2007, 12:38 AM   #9
twofourty
twofourty's Avatar
No, the key only gets stuck when thr turbo timer is on and works normally when it is off. In other words I have to shut the timer off just to get the key out.
Old 04-15-2007, 02:07 AM   #10
mrmephistopheles
mrmephistopheles's Avatar
Christ.
Pop off your steering column surround.
Find the solenoid that locks the key in place.
Disconnect the spade clip that supplies it power.
Once that's done (before reinstalling trim), test the system.
Turn car off, REMOVE KEY, and see what happens.
Originally Posted by PHLIP
Old 04-15-2007, 02:12 AM   #11
Brailleauto
Brailleauto is a well-known jackass
Originally Posted by mrmephistopheles
Christ.
+1
Exactly what I was thinking.
Brailleauto is offline   Reply With Quote
Old 04-15-2007, 03:41 AM   #12
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
Wait, I've got a very similar issue with an s13 that I swapped from auto to 5spd. The key gets stuck in the ignition after the engine is turned off, and will only release after what looks like a tiny red 'tab' is lifted. The tab I'm referring to is located behind the ignition lock, and underneath the top steering column guard.
Earlier a parking release was mentioned - maybe my wiring wasn't complete. Is there a parking release switch that must be re-wired to allow the key release button alone to let the key out?
s13_gearhead is offline   Reply With Quote
