Old 04-22-2007, 12:00 PM   #1
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
S13 Battery Tray Removal
To anyone that has removed a battery tray out of an S13 (preferably, but even an S14)...ANY TIPS?
Where are the spot welds/bolts? I've found 4 welds and removed every bolt I can find...am I missing something, because this mofo seems to be welded in tight.
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 04-22-2007, 12:31 PM   #2
JewGal
JewGal's Avatar
JewGal is a well-known jackass
There are more than 4 spot welds. Keep searchin'.
JewGal is offline   Reply With Quote
Old 04-22-2007, 12:35 PM   #3
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
to the best of my knowledge there are at least 12 spot welds holdind it in. You have to look carefully, but you will find them all. Drill them out, cut, grind and it should come out.
Couple pics of my S14 removed. You can kind of tell where the spot welds were.
khilgers is offline   Reply With Quote
Old 04-22-2007, 01:48 PM   #4
DynastyJAM
DynastyJAM's Avatar
DynastyJAM can only hope to improve
Send a message via AIM to DynastyJAM
i pretty much found the obvious welds, n took a chisel n hammered through them (after cutting the brackets holding it to the bay). then realized there were like 10 more welds in the middle that are like impossible to get to, so i got frustrated, took a long bar, and jus pried the holding off. lol it actually worked great, but theres probably a chance that you can pop a hole into your engine bay
DynastyJAM is offline   Reply With Quote
Old 04-22-2007, 02:11 PM   #5
projectRDM
projectRDM's Avatar
There are sixteen spotwelds total.
