Old 05-13-2007, 09:42 PM   #1
gunbbang82
gunbbang82 is an unknown quantity at this point
Send a message via AIM to gunbbang82 Send a message via MSN to gunbbang82
s14 injen intake install problem
I just finished installing s14 injen intake on my 97. I noticed that there were only 2 nipples for the hoses instead of the 3 hoses ka24de has. one small, 2 big. I first just left the breather hose not connected to anything. But i felt uneasy knowing that unfiltered air was going in there so i made a ghetto solution. home depot + T junction.
Will this be okay? I checked the the junction to see if its getting any oil from the breather but it was clean. Is there are better solution?
gunbbang82 is offline   Reply With Quote
Old 05-14-2007, 03:53 PM   #2
The Stig
The Stig is an unknown quantity at this point
Thats the way i hooked up my ebay intake which is like an injen copy. For piece of mind you could put a catch can between the T fitting and the valve cover hose.
The Stig is offline   Reply With Quote
Old 05-14-2007, 04:30 PM   #3
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
My intake came with that T fitting
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 05-14-2007, 09:26 PM   #4
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
My Injen came with a T fitting as well. That will be fine, but if you're worried just put a couple small hose clamps on the ends to tighten it up. Or just put together an aluminum intake box in the spot where your battery is and relocate it to the trunk...thats what i finally did, i never liked the idea of having my "Cold Air" intake running over top my hot ass radiator and sucking in air from the exhaust side of the engine bay. Anyways, good luck!
The Chad is offline   Reply With Quote
Old 05-14-2007, 09:29 PM   #5
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
hows the 3 horsepower treating ya
benefitx is offline   Reply With Quote
Old 05-14-2007, 09:49 PM   #6
gunbbang82
My ass dyno isn't very accurate, but it does sound a lot meaner when i stomp on it. But then again, i have heavy ass sport max rims... probably negated the effect of the intake and then some. =T
Old 05-14-2007, 10:53 PM   #7
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
or you can just go to pepboys and get one of those mini filters and attach it to the the valve covor entry one.
silnismo is offline   Reply With Quote
Old 05-15-2007, 11:38 AM   #8
!Zar!
!Zar!'s Avatar
Funny, when I speak out my ass, all I get is a fart. How long did it take you to learn how to do that?
Yay for rice mods. That hose blows out air. It doesn't suck it in.
Uuugggggghhhhhhh.
Old 05-15-2007, 06:11 AM   #9
98koukile
98koukile's Avatar
Don't they run the intake to the other side because the maf needs to be more than 11" from the throttle body or it goes wacky?
Old 05-15-2007, 08:19 AM   #10
180sxLove
180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about
^ close to that. thats the reason you place the MAF farther away from the throttle body on a blow through MAF turbo setup.
180sxLove is offline   Reply With Quote
Old 05-15-2007, 12:23 PM   #11
Irukandji
YAyyy for blowby using those shitty ass breather filters.
Old 05-15-2007, 02:21 PM   #12
gunbbang82
I noticed that when the breather was left free and not connected to anything, my rpm would drop to like 300rpm when turning the steering wheel without any gas. Whenever i was about to get out of the parking spot, the engine would bog considerably cuz i would be turning the wheel from lock to lock with no gas. (NYC... TIGHT parallel parking) Is there a reason to that?
Old 05-15-2007, 02:25 PM   #13
enjoidorifto14
enjoidorifto14's Avatar
enjoidorifto14 can only hope to improve
Why would you start a thread when you already fix your problem?
enjoidorifto14 is offline   Reply With Quote
Old 05-15-2007, 02:28 PM   #14
gunbbang82
As stated in the original post, I wanted to make sure there was nothing wrong with the "fix" that i had and see if there are better solutions out there.
Old 05-15-2007, 02:50 PM   #15
enjoidorifto14
well he should have check and read the instuction first before installing it. He could have find out that his missing the 15mm plastic t fitting that came with it.
