Old 05-22-2007, 04:09 PM   #1
skylindrftr
skylindrftr's Avatar
Trader Rating: (26)
skylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfection
Feedback Score: 26 reviews
300ZX brake rotors ques + wastegate ques
ques 1: Will 300ZX rotors work with s13 silvia abs calipers (provided they are drilled for 4 lug)?
ques 2: Will a small crack below the wastegate hole on a t28 make spooling noticeably worse?
Thanks!
skylindrftr is offline   Reply With Quote
Old 05-22-2007, 04:53 PM   #2
OptionZero
OptionZero's Avatar
1. No
1a. What is so hard about using s13 calipers with s13 rotors or 300zx rotors and 300zx calipers?
Old 05-22-2007, 04:57 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Below the wastegate hole? compressor side? Wait lemme re-phrase that, the shiny side of the turbo or the non-shiny side of the turbo?
S13 brake rotors are too small for 300Z rotors...
CLICK HERE!!!
Old 05-22-2007, 05:39 PM   #4
skylindrftr
Trader Rating: (26)
OptionZero, I am already running altima rotors with my s13 calipers, but my buddy gave me some predrilled 300zx front rotors for free but i haven't had the time to bolt them up yet jw...
fliprayzin240sx, there is no wastegate on the compressor side buddy =) Thanks anyhow
Old 05-22-2007, 09:54 PM   #5
projectRDM
projectRDM's Avatar
But you know for a fact that the 300ZX rotor is both larger in diameter and wider, so how do you propose to make it fit?
That's like asking if a 15" tire will fit on an 18" wheel, you know the shit won't work, why even bother asking?
FORMERLY R240NA
Old 05-23-2007, 11:56 AM   #6
steve shadows
steve shadows's Avatar
Thanks!
I wouldnt bolt any turbocharger into a car with any visible fissures...but hey its your life
got a pic?
Like Me on FaceBook !
Old 05-23-2007, 03:04 PM   #7
skylindrftr
Trader Rating: (26)
r240na: it is larger but the rotors I am using right now are still a bit small, they are smaller than 180sx/s13 sil rotors and my buddy gave me some 300zx ones and said mabye they will work mabye they wont...
Steve shadows: I talked to a guy where my buddy works at a machine shop and he said it i wont lose enough exhaust gas through it to noticeably affect response. Here's a pic:
Old 05-23-2007, 05:30 PM   #8
MomentumGT
MomentumGT's Avatar
MomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to behold
Doesn't look like the crack or scratch would do you any notice. To me I think you're good.
-Jon
momentumgt.com - "building blocks of speed"
MomentumGT is offline   Reply With Quote
Old 05-23-2007, 03:16 PM   #9
OptionZero
OptionZero's Avatar
your friend is an idiot, and you're only a little farther behind
how hard is it to get replacement s13 rotors, some fools in socal would probably give you some decent condition ones for free
Old 05-23-2007, 05:19 PM   #10
skylindrftr
Trader Rating: (26)
Look I didn't ask to be insulted I don't see what your problem is, a simple yes or no would have done. I got these rotors for free, so I was jw. This forum is a lot hostile than I remembered it. Also the rotors that would be ideal for this setup are the real s13 silvia/180sx (not 240sx) front rotors.
Old 05-23-2007, 05:52 PM   #11
skylindrftr
Trader Rating: (26)
Thanks, it's just that little crack right there and it wraps a teeny bit under the wastegate on both sides.
Old 05-26-2007, 06:57 AM   #12
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
cracks are bad on the any side of a turbo. especially the turbine side. your spool up will be bad and the crack will only get bigger the hotter the turbine gets. and they get hella hot, enough to melt flesh instantly. trust me i know first hand. second, the 300zx rotors will only work with 300zx calipers. they are way larger diameter and also much thicker than the stock s13 rotors. so no they wont work. sorry that every one is hostile, but the rotor question is very basic common sense. just to clarify, the 300zx rotors will work on an s13/s14 but you must have the matching 300zx calipers. (ie. 26mm rotor & caliper or 30mm rotor & caliper) hope this helps you out
misfitsfreak81 is offline   Reply With Quote
Old 05-26-2007, 08:41 AM   #13
91rps13
91rps13's Avatar
91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice
+1. on a side note uf you got free rotors why not think about upgrading to z32 calipers??
No more 240
91rps13 is offline   Reply With Quote
Old 05-29-2007, 04:59 PM   #14
skylindrftr
Trader Rating: (26)
Well I have considered z32 calipers but I have been dealing with turbo issues lately and found out that I need a new compressor o-ring seal as well, anyone know if it possible to seal this crack in the turbine?
