Old 05-26-2007, 04:37 PM   #1
Boosted-Alty
Boosted-Alty is an unknown quantity at this point
3 weeks and still no spark on the S13
I have changed out everything. Can someone help. I changed the dist, coil, module, relay, wires, ecu. What should I check next?!
Boosted-Alty is offline   Reply With Quote
Old 05-26-2007, 07:58 PM   #2
johngriff
johngriff's Avatar
Is the ECU getting power? Do you have a multimeter?
[email protected]
Old 05-28-2007, 01:04 PM   #3
Boosted-Alty
yes it is getting power
Old 05-28-2007, 01:12 PM   #4
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
first check signal coming out of dizzy, if yes move to coil, if no its a problem in the dizzy
check power to coil, check signal to coil, if you have both of these, the coil should function, check coil output, if no output, check coil resistance. if coil is good, wires and plugs.
check your engine grounds too.
basically either there is a problem with a component in the ignition system, or your ecu is seeing some reason not to give spark. you will be able to determine this by scoping the trigger signal going to the coil.
hope that gives you some place to start
lazierhobo is offline   Reply With Quote
