Old 06-02-2007, 12:40 PM   #1
S13-KA24DET
S13-KA24DET can only hope to improve
Perrin manual boost controller anyone? help understanding/installing MBC
bought off my friend, lost the instructions
#1. goes to the wastegate actuator(s) while..
#2. goes to the vac source/intake plenum?
or does it really matter?
and anyone running this MBC, just wondering how to set it at stock boost, how many turns clockwise (tighten) or counter-clockwise (loosen) per 1 PSI or what not
S13-KA24DET is offline   Reply With Quote
Old 06-03-2007, 01:19 AM   #2
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
Buy a boost gauge (if you haven't already).
I would suggest #2 going to the intake manifold.
There isn't an exact science when adjusting a mbc. I suggest a half turn at a time, then test at wide open throttle (on the street).
Repeat until desired boost is reached.
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 06-03-2007, 01:35 AM   #3
garbury
garbury is making a name for him/her selfgarbury is making a name for him/her self
Well if it is a ball and spring, and they are in that order...then you want the line from the vacuum source to push immediately against the ball which will be controlled by the spring pressure.
Vacuum source - 1
To the Wastegate Actuator - 2
If you flip it around, then the boost pressure will just push the ball into place, blocking the nipple and your boost will spike since the wastegate actuator will never get any signal.
To tune it, just turn counter clockwise a ways (its better to just be too loose than too tight since too tight means too much boost. Too loose will just leave you at stock boost). then give it a good romp in 2nd or 3rd and keep tightening until you hit desired boost.
garbury is offline   Reply With Quote
Old 06-03-2007, 11:45 AM   #4
S13-KA24DET
alright i just tried that gary
but i tightened it all the way and it's still boosting at stock?
maybe the mbc is faulty or would you guys think having stock twin turbo's play a factor?
you think i should try replacing the spring with a stiffer one?
