Old 06-13-2007, 05:17 PM   #1
Bronze MFP
Bronze MFP is an unknown quantity at this point
Rb20 Swapped s14
1995 Nissan 240sx with RB20DET swap. The swap was performed by myself and a friend december of 2005. At the time the water pump, timing belt, timing belt pullies, thermostat and clutch were replaced. The engine has performed flawlessly since the first time it was fired up. Oil has been changed every 2500 miles and 20W-50 weight run in the summer and 10w-40 for the winter. This car is a great, quick daily driver. It has never left me stranded and has enough power to bring a smile to your face. Have not had it on the dyno but it will pull on 350z's and G35's. Beside the engine swap, the car has brake and suspension upgrades. A full (at least as well as i can remember) list of parts is listed below. This car has taken me 2 years to build. I'd rather not sell it, but need to move on with other areas of my life.
Asking $11,500 price negotiable.
Looking for a good MR2, mkIII supra or older M3 as well
Any and all questions welcomed
[email protected]
-Neil
Heres a vid of it in action:
my car vs carl h's car
http://www.youtube.com/watch?v=WjN-m3kuxZA
Note that my car is a pretty stock rb setup, my buddy is running a gt30r, cams and a bunch of other engine mods.
List of parts:
Suspension:
KTS Coilovers
Nismo Power Brace
SPL Parts Adjustable bump steer tie rods
SPL Parts Fender braces
SPL Parts T/C Rods
SPL Parts aluminum differential bushings
Solid Subframe bushings
Cusco Rear upper control arms (camber adjustment)
Stock front and rear sway bars
R32 GT-R wheels (16x8, 30 offset 205/55/16 tires front 225/50/16 rear)
also have the stock SE wheels painted graphite with tires, and a set of 16x7 front and 16x8 rear enkei racing S wheels.
Drivetrain:
1993 Skyline GTS-T Type M RB20DET (estimated 50Kmiles on motor at time of swap, the motor was and still is in great condition. no trouble from it EVER)
Nismo engine and transmission mounts
RC Engineering 550cc injectors
Chip tuned stock ECU
Tomei Performance fuel pump (good to 450hp or so)
AM Performance turbo elbow
HKS 3" Downpipe
Espelir GT500 exhaust
Greddy Timing belt
RPS Street performance clutch (holds up to 300ft/lb torque)
JUN lightweight flywheel
Apexi air filter
Tomei Technical Trax Advance 2-way LSD
Brakes:
300zx 4piston front calipers 300zx 2 piston rear calipers 300zx Working drum ebrake Braided steel brake lines
Axxis Metal Master pads all around
Valvoline dot4 high performance brake fluid
Gauges:
Greddy 60mm boost gauge
Greddy 60mm Coolant temp gauge
Greddy 60mm wideband o2 gauge
Cooling:
Dual permacool 12" fans rigged to a DIF fan controller
Coolant changed at last oil change (~1000 miles ago)
Autotrader Ad:
http://www.autotrader.com/fyc/vdp.js...ag=1&cardist=0
Bronze MFP is offline   Reply With Quote
Old 06-14-2007, 02:17 PM   #2
sikkk240
sikkk240's Avatar
sikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond repute
Send a message via AIM to sikkk240
free bump for a clean car..
gl with sale. =]
sikkk240 is offline   Reply With Quote
