this guy i met has a 91 na 300sx rear end.he says it has bad PINION BEARINGS .what are those?does it have anything to do with the vlsd?and what else would i need for this swap?thanks alot for your help!
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
You could replace the bearing yourself, but you'd have to make sure the pinion's lash lines up (the pinion and the gear mate up correctly). Best thing to do would be have a gear shop do it for you.
If I'm not mistaken, the output shafts on the Z LSD are a five star bolt pattern (with a bolt hole on each star point), and the S13 has 3 stars with 2 bolt holes on each of the 3 star points. So, you'd need the output shafts and the bearing replaced. -m
400x200 ![]() |
