![]() so i had my ka24de taken apart and i noticed the little butterfly plates in each intake runner where the manifold is bolted to the head and i removed them off of the the shaft that they were screwed on to and i put it back together without the plates and it ran like shit so before i start to take it all back apart to put the plates back in is there anything that i can do to get it running right it wont even idle it fluctuates like if it had cams or something between 300 to 800 rpm up and down and then it stalls out but for now im planing to get it going with the little plates so if someone knows please help
#2 | |
![]() Join Date: Dec 2006
well more than likey cuz of taking off the Butterfly Valves its F'n up your A/F ratio at idle (your getting more Air @ idle) so your AIC & ECU are trying to compensate
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 08-28-2007 at 10:35 AM.. |
![]() Join Date: Dec 2002
IT HAPPENED CAUSE YOU'RE A COMPLETE IDIOT WHEN IT COMES TO WORKING ON CARS.
Why the hell would you remove those???? They're connected to your swirl control valve. It is an idling component that, when removed will cause your car to run like crap. There's absolutely no reason to remove these, none. EDITED: REMOVED INFO - RUSS SAID IT ALL.... ![]() Better yet...you're local, sell your car to me and I'll give it a good home with a knowledgable owner. Plus it'll help keep another 240 where it belongs, out of "Riceland". sheesh....
Don't mess with my monkey...he's loaded. |
Actually, no. The SCVs are part of the 91-early 93 intake manifold, designed to help lowend power since they use the more aggressive camshafts. They can easily be removed for less restriction without any ill effect, as later 93-98 models don't have them at all, and amazingly there's a million writeups and detailed instructions all over the internet explaining how. As long as the two open ports to atmosphere are plugged, you're fine with removing it.
Sadly though, to the OP, your one big ass sentence without a shred of punctuation, capitalization, grammar, or even intellect tells me you're not only the stupidest fucker on Earth, but your mechanical skills are on par with a tree stump and you have no clue what you've done or how to fix it. Sell the car, buy a gun, place it in your mouth, and pull the trigger. You'll be doing us all a favor.
#5 | |
Well
THE REASON I TOOK THEM OFF IS BECAUSE I HAD A GTS COUPE WITH A 3SGTE WTH THE SAME TYPE OF PLATES, I REMOVED THEM AND THE CAR RAN WEY BETTER
^^daaammmmnnnn^^
![]() Join Date: Aug 2006
english class 101 FTW.
go back to school pass gen. ed classes. After that begin taking apart lawn mower engines and learn from there. also one might suggest to give that 240 a good home the two stated above should be good keepers.
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd ![]() Boycott Berkeley and code pink |
Well I Dont Think That Was The Problem
SO TODAY I SPENT THE WHOLE DAY WORKING ON SILVIA AND ONE OF THE THINGS I DID WAS PUT THE PATES BACK IN THE INTAKE RUNNERS
WELL THE AFTER MATH WAS NOT THAT GOOD IT STILL IDLED LIKE SHIT AND FOR NORMAL DRIVING IT WAS BETTER BUT BEFORE WHEN I DID NOT HAVE THE PLATES IN IT WOULD ABSOLUTLY RUN LIKE DOG SHIT FROM 1000 RPM TO ABOUT 2900 THEN AFTER 3100 IT WOULD THEN THE RPMS WOULD FLY UP FAST BUT ONCE I HIT 6500 IT LOSES POWER WHITCH IS NORMAL FOR THE KA DE BUT NOW WITH THEM BACK IN SIL FEALS WAY SLOWER SO ALL IM CONCERNED WITH IS GETTING IT TOO IDLE RIGHT AND WHEN I AM IN ANY GEAR CRUSING BELOW THREE THOUSAND RPMS WHEN I LET OFF OF THE GAS AND RPMS DECELERATE I GET BACK ON IT I JERKS LIKE A TEN YEAR OLD KID LEARNIG TO DRIVE STIK SO I AM FORCED TO DOWN SHIFT THEN UP SHIFT SO I DONT KNOW WHERE I SHOUD START AT BUT INSIDE THE INTAKE PORTS VALVE STEMS AND MANIFOLD IS ALL BACK LIKE THE EXHAUST SIDE SO IM THINKINKING IT COULD BE SOMETHING IN THE DRIVABILITY SYSTEMS AND OR AN INTERNAL MECHANICAL PROBLEM SO CAN SOMEONE PLEAS GIVE ME SO ADVISE ON GETTING THIS KA24DE RUNNING RIGHT THANX FOR READING ![]() |
Sounds like you have the same problem I'm having with mine.
Do you know how to pull codes? Sounds like you might have a faulty TPS(throttle position sensor). Pull the engine codes(if you can do that without killing yourself) then get back to me. I think that's all the direction you can handle at this point. Any more and you'll probably have an anurism.
Admin Asshole
![]() Join Date: Mar 2002
Turn off the damn CAPS LOCK and learn how to use punctuation.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
![]() Join Date: Apr 2006
and its not a silvia damnit
2015 Subaru Outback Overlander - Wagonofdoom |
#15 | |
![]() Join Date: Jul 2005
Damn and all this time I've been thinking all these 240sx' with Silvia front ends were Silvias. I'm just going to end my life now.
#16 |
![]() I TESTED THE TPS, MAF, ECT, AND I STILL HAV THE O2, CRANK ANGLE, AND THE CRANK TO CAM TIMING ALSO I WAS WOUNDERING IF ANYONE HAS A PRECISE PICTURE OF THE CAM SROCKET POSITION WITH NUMBER 1 CYL AT TOP DEAD CENTER OF COMPRESSION. Oh sorry about the typing i thought this was a sight that im able to obtain usfull information for my silvia not to be critisized. So the tests that that i did were in spec so now im going to flash some codes out from the ecu, I also was going to take it to an old shop i used to work at and use my old bosses modis.
#17 |
Admin Asshole
It's still not a Silvia, it's a 240sx.
If you are looking for information for your 240sx then you need to do it in a manner that can be easily understood. Typing with Caps Lock on and not using any punctuation makes it rather difficult to understand. If you can't take criticism, you may want to seek advice elsewhere.
#18 |
that still doesn't make it a damn silvia.
Shut the hell up and your questions have already been answered about the butterflies. If you didn't plug your holes that the butterflies left open to atmosphere, cover those and come back. I didnt even bother reading your posts as it got me angry by just looking at it. How about learning to spell!? /END thread. |
#21 |
plug up the ports with jb weld. port it out. simple seal. punctuation is an awesome tool as it seperates one sentance from the other thereby making it easier to read and comprehend.
