Old 08-31-2007, 03:06 PM   #1
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
HID retrofit?
Thinking of doing a bi-xenon retro in my flip-ups, and was wondering if anyone has already done so? Or, is there a write-up that can help me get this done?
speedgod^s13 is offline   Reply With Quote
Old 08-31-2007, 03:56 PM   #2
unwed_transient
unwed_transient's Avatar
unwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond reputeunwed_transient has a reputation beyond repute
you will have to search on hidplanet.com's forums. no write-ups exist for the s13 but you can gather general knowledge on how to piece together your setup. read up on projector dimensions, wiring, etc. you will have to do a significant amount of fabrication.
one guy did a bi-xenon retro on his s13 but was unable to lower his lights.
another guy did a retro in an ae86 and was able to retain up/down motion.
search for "s13" and "7x6" over there.
unwed_transient is offline   Reply With Quote
Old 08-31-2007, 05:39 PM   #3
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
Yes, go to hidplanet and do some research, The guy your talking about unwed did not use bi-xenon's just single xenon TSX projectors. Bi-xenons will most likely be quite a bit larger in size. I have a pair of TSX projectors I was going to try to retro and keep the flip-up function, but with taking measurements, its not easily do-able. You would have to cut the rear section of the headlight bracket out for sure and maybe even notch the core support.
Im sure if you searched you could find shorter projectors that may fit, but I doubt they will be bi-xenon's, its possible though.
Good luck if you plan on doing it, and make sure you post some pics.
-Trevor
sidewayz240 is offline   Reply With Quote
Old 08-31-2007, 05:59 PM   #4
speedgod^s13
I did some reading on hid planet, and it is hard to keep the flip up option, when retrofitting. For a temporary fix, i'm going to install a d2s kit, and use my casper shields. That is, until I can get my funding for the retro.
Old 08-31-2007, 06:27 PM   #5
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
ohh shit where is mike.....
CKAMC is offline   Reply With Quote
Old 08-31-2007, 08:57 PM   #6
speedgod^s13
NOOOOOOOOOOOOOOOOOOOO!!! I don't want any trouble!!!!
Old 09-22-2007, 10:40 AM   #7
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
@adrianfromthecastle
Old 09-01-2007, 02:29 AM   #8
Sag3r
Sag3r's Avatar
Sag3r is an unknown quantity at this point
Acura TL projector is the way to go. I'm doing a custom retro fit on my s13 headlights and when I'm done I'll post up a write up.
Sag3r is offline   Reply With Quote
Old 09-01-2007, 12:18 PM   #9
Bushido
Bushido's Avatar
ive heard good things about "blazer" fog lights. they are made to use a halogen bulb (H3 i think) but the cutoff is not really that bad when used in conjunction with an hid system. what is great about these are, they are waterproof, compact, and cheap. in the near future i might try to fit one in my pop-up H4 housing. i think with how shallow they are i should be able to flip them down.
these are pretty sweet also...
http://www.hidplanet.com/halogen.html
Old 09-01-2007, 12:47 PM   #10
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
there are actually a few drop in HID projectors conversion kits for our S13 flip headlights
http://www.brightheadlights-hid.com/hid-upcoming.htm
im currently using Hella H4 conversion kit though but the cut off line is sharp. im definitely gonna try to put some HID in them.
you can check out the cut off line here
http://www.zilvia.net/f/showthread.php?t=152196&page=6
Ragnarok043 is offline   Reply With Quote
Old 09-01-2007, 06:11 PM   #11
speedgod^s13
Well, I currently have the hella h4 conversion, and I was running HID's in there. They weren't retrofitted, but they looked nice. Until both HID's crapped out. I don't know how, but both sides just stopped working. My friend tested the voltage, and there was power going to the bulb. The bulbs aren't burnt out either. I don't understand how both sides could crap out. It wasn't no cheap HID kit either. It was a Phillps ballast, Phillips igniter, and Phillips bulbs. When my friend first put them in, they powered up fine. I'm thinking that since I mounted the ballasts right underneath my flip-ups, that when I got my car washed, water probably got to the place where the igniter plugs in, therefore causing a short. I can't think of any other reason, why both sides would not work. After checking out that link, I think i'd rather spend 500, than a thousand something for hid's. Although, it's pretty sweet that the kit is just drop in.
Old 09-01-2007, 03:45 PM   #12
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i did mercedes e-class bixenon projector into the s13, but it's not popup lights, shucks =b
I don't see why it can be done, just wire it up to the headlight, the only concern is that there's lack of space, i talked to one guy who just used a metal plate or sheet of cf or something and bolted the projector to that.
240meowth is offline   Reply With Quote
Old 09-22-2007, 01:18 AM   #13
fueled by hate
fueled by hate is making a name for him/her selffueled by hate is making a name for him/her selffueled by hate is making a name for him/her self
There's a write up on nico. Acura TL's
fueled by hate is offline   Reply With Quote
Old 09-22-2007, 03:23 PM   #14
ixfxi
Guest
Posts: n/a
wow those look SO fucking AWESOME
looks like the car should've come like that, from the FACTORY
the johnny-5 factory
Old 09-22-2007, 10:26 AM   #15
Diabolical
Diabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymore
Ever heard of the search button noob? Or maybe, try googling it to find the nico or other 240 website article? Use you head noob.
Diabolical is offline   Reply With Quote
Old 09-22-2007, 04:23 PM   #16
UfoZ8myCow
UfoZ8myCow's Avatar
Or if youre baller enough...
http://www.clearcorners.com/products...0sx1/f_lowpro/
UfoZ8myCow is offline   Reply With Quote
