I read someone's post about removing the speed cut on an S14 a couple days ago and thought I would try it on my S13. It involved disconnecting the 5th gear sensor on the trans and cutting a yellow ECU wire with a green stripe and two silver dots every inch or so. On the S13 (at least mine) there is no such wire, but a yellow wire with a green stripe and a single silver band about every inch. There's actually two such wires, but only one goes into the ECU while the other bypasses it. I checked my Chilton's schematic and confirmed that this is still the speedo wire. I figured theres enough slack to splice it back together if it didn't work, so I went ahead and cut the one going into the ECU. Whoo-hoo, I took it out in the country and managed to wrap the speedo needle to the first odometer number! Although this proceedure is supposed to turn on the check engine light on the S14, mine has not come on. It flashes on startup, so I'm sure it works. I might put a switch in the kickpanel so I can turn it on or off if the light ever goes on. The 5th gear sensor is the same as the S14, its the rearmost one in the cluster of three small sensors on the right side of the tranny. Hope this helps somebody out there. BTW, my S13 is a '91 with the stock KA24DE and ECU. And of course, I'm not responsible if you screw up, get a ticket, blah blah blah, etc.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (orange-grey @ Sep. 06 2002,10:08)</td></tr><tr><td id="QUOTE"> Whoo-hoo, I took it out in the country and managed to wrap the speedo needle to the first odometer number!</td></tr></table><span id='postcolor'>
Heh, you're my hero <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> I read that one post and allt he side effects scared me off, then at Radio Shack today, I saw some switches I could mount on the kick panel if I extended the wires. Just like you are thinking about doing. hell, I may try that. I tried to whoop up on an automatic riced out Saturn SC2 on the interstate and I had it until I was coming up to my governor, so I backed off <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=' ![]() Thanks for being cool enough to be a guinea pig <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle.... Rattles are just your cars way of saying 'I love you.' |
![]() Join Date: Sep 2002
any way to do it to an s13 sr20det?
'91 fastback. '97 S13 blktop SR20DET. Cstm Frnt Mnt IC w/ cstm 2 1/2" piping. stnls stl fltr. 3" cstm DP & exhst w/N1 muff. Walbro FP. ACT 6 pck cltch. Go Fast Bits crnk plly. Ground Control coils. KYB AGX shks. 12.98@106 w/g-tech pro. 17psi. All work and fabrication done by ME |
i dont get why you would do both, would not one or the other work?
Matt "andy offers kevin pudding at 9, if andy is 7 years older then pudding than how many liters of andy does it take to get to detroit?" "There are 3 types of people in this world. People who can count, and people who cant.." ""Save the Whales" (Trade them for valuable prizes)" |
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Mtt22 @ Sep. 09 2002,10:35)</td></tr><tr><td id="QUOTE">i dont get why you would do both, would not one or the other work?</td></tr></table><span id='postcolor'>
nope |
why not? if you cut the wire the computer will not be able to read yoru speed, and if you remove your 5th gear sensor.... fuck i dont get it
![]() Join Date: Oct 2001
My understanding of it is the tranny has a sensor on the output shaft of the tranny to measure absolute speed. However there is also a sensor to tell what gear you are in. If you are in 5th it makes the rev limit lower.
For a demonstration of this, put it in 5th while stopped, and rev it up while hodling the clutch down. It will only let you rev to arround 5000something. |
oh, it all makes sence now, thanks
there is one, apparently once you cut the wire the ecu goes into some kinda "warning mode" or something and no longer stores codes or something, i dunno, was in the last speed limiter removal post a few weeks back
Wich two wires are we talking about here, exactly? Am I correct in assuming that if you disconnect the speed sensor, you render your speedometer useless, making this modification useful only for racing purposes, not for determining top speed? Anyway, where is the fifth gear sensor, and is the crucial wire on the SR20 still yellow w/green? All I remember hooking up when doing the swap was the reverse, and speed sensor. It's been a while, though...
We are still talking about SR20's here, right? --luke
hey, I tried that and for some reason, my car wouldn't let me rev past 4500 in 4th gear, and 4000 in fifth, plus I couldn't go over 90! what gives? is this because I could have pulled off the wrong tranny sensor? which one am I supposed to pull off? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
strive to be the fastest |
