Old 09-16-2007, 03:09 PM   #1
chesterfieldking
chesterfieldking is an unknown quantity at this point
car wont start
i have a 91 240sx with sr and my car wont start
it all started when i disconnected the negative terminal from my battery 2 days ago. when i got back i put the battery back on and it started normally, after driving it for about 5 minutes the engine sounded like it turned off and my revs drop slowly until i came to a stop. and when i gave it gas it wouldnt respond. i tried to start it, it cranked but wouldnt start. so i get it back to my friends house disconnect and reconnect(small sparks when i connected the positive terminal) the battery again and try to start the car and it starts perfectly. yesterday i took the car out, it started normally but about 5 minutes into driving it dies the same way as the day before. i noticed that when i tried to start the car and took the key out the egi relay makes a clicking noise until i try to start it again or disconnect the battery. this morning when i got home i took another look at the fuse box and the egi, egi pump, and the relay next to it were significantly warm, even though the car had been off. i bought this car this car a little more than a week ago and it has never given me any problems like that until the day i disconnected the battery, anyone have any ideas?
chesterfieldking is offline   Reply With Quote
Old 09-16-2007, 05:43 PM   #2
chesterfieldking
so i got it to start again right after connecting the battery. ran for a few minutes before dying again. the egi relay is still making a buzzing noise after i take the key out, anyone know what that means?
Old 09-16-2007, 07:12 PM   #3
chesterfieldking
also i dont hear the fuel pump whining noise
Old 09-17-2007, 12:12 PM   #4
chesterfieldking
switched out the buzzing relay, still wont start. i started the car a few times yesterday but it dies like its out of gas. someone said it might be a "bad ecu" could that have happened when i messed with the battery? this might be nothing, but i notice the car starts when i connect the positive terminal and see sparks.
Old 09-19-2007, 10:41 PM   #5
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
if you see large sparks when you connect the terminal it means that you have a large amperage draw. Pull the fuses one by one untill the LARGE sparks no longer accure. If you have a multimeter this would be easier because you can read the amperage draw for each circuit that your opening by removing the fuse.
RedtopTech is offline   Reply With Quote
