![]() Join Date: Mar 2004
Rubber thing in the center of the driveshaft...
The rubber ring that is at the center of my driveshaft fell apart and is now 4 pieces...
How do I replace that?... There isn't a part number just for that... And do I need to replace it?
http://respectvolkracing.blogspot.com/ |
lol
go one piece. but I heard 1 piece are back ordered. Im pretty sure there is a part numper for that, unles it's part of that portion of the driveshaft. not 100% sure though
Like Me on FaceBook ![]() |
![]() Join Date: Jul 2007
Its the carrier bearing, take it to napa, buy it and have them compress it out, will come out to be like 50 bucks total. It's only 6 bolts.
-Disconnect the drive shaft to differential - Size 14's I believe, -Unbolt the part that holds the carrier bearing - Size 17's I believe, -Slide the whole driveshaft off, disconnect the big part from bottom part - Size 17 bolts I believe, Take it to autozone buy the bearing like 35$ take it to Napa have them take it off and put the new one back on. and then your done. |
-Disconnect the drive shaft to differential - Size 14's I believe, ![]() -Unbolt the part that holds the carrier bearing - Size 17's I believe, ![]() -Slide the whole driveshaft off, disconnect the big part from bottom part - Size 17 bolts I believe, ![]() Take it to autozone buy the bearing like 35$ take it to Napa have them take it off and put the new one back on. and then your done. |
Bingo...
Is it possible to change the bearing myself or does it take special tools? I also found it on Courtesy's website... Center bearing insulator... $27.22...
![]() Join Date: Dec 2002
You'll need a press.
