Old 09-16-2002, 03:22 PM   #1
sxtasy
Guest
Posts: n/a
I was looking at buying the Venom VCN-1000 to add a little Nitrous to my KA. My engine has 90k miles on it but has been very well maintained and has like new compression readings with only 1-2 psi difference between cylinders. My question is, has anyone installed this kit on a stock (internally) KA? and if so, what was the outcome.....  I read a review on an install on a stock Toyota 22R engine, and they raved about it.  Thanks in advance!
-Steve
Old 09-17-2002, 10:25 AM   #2
sxtasy
Guest
Posts: n/a
Nobody has added nitrous to a KA? I did some more research and found the ZEX kit to be a better system overall and I found it online for $100 less than the Venom kit. ZEX installed this system on a pretty much stock 98 Civic and ran a 13.6 1/4 mile! not bad for $500! It also monitors the O2 sensor and will shut down if the fuel system leans too much.
***OOPS, I wasn't using the search propperly &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'> &nbsp;........never mind........
Old 09-17-2002, 07:45 PM   #3
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
this place is anti-nitrous <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
240SX Forums
http://forums.freshalloy.com/ubbthre....d=UBB27
Edit: just read your signature. that's from the show "eyedrops". hehe.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 09-18-2002, 10:55 AM   #4
sxtasy
Guest
Posts: n/a
Your right whateverjames, here's a link..... Space Robots
Old 09-18-2002, 11:17 AM   #5
240racer
240racer's Avatar
240racer is an unknown quantity at this point
yeah everybody here is turbo all the way :-)
anyway, I think nitrous is a very good way to go, especially if you like to go to the drag strip and show the hondus and cameros a thing or two.
I just don't have experience on the kits, I was looking into pieceing one together for my car. &nbsp;I was just going to start with the sniper kit since it's cheap
I think they are all pretty much the same, so whatevers cheapest. &nbsp;
However, as far as what the stock internal engine can handle, well I am making about 90hp more then stock with the turbo, so you should be able to do about the same with nitrous.
Figure on the 75-80 shot or something
have fun
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 09-18-2002, 12:00 PM   #6
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
I'd get it if i was on a budget. &nbsp;You'll probably love it (who does'nt like 50+ HP with the flick of a switch) &nbsp;Sounds like the company making the kit took everyting into account and its setup good. &nbsp;Couple that with your well mantained engine and I would'nt expect problems.
ca18guy is offline   Reply With Quote
