Old 10-19-2007, 10:12 AM   #1
nismobeyond
nismobeyond is an unknown quantity at this point
CA18DET: Stalls, TONS of black smoke
Whats up guys,
Car is an S13 powered by a CA18DET. I have had a fuel injector leaking a little drip of fuel onto the block because of a bad o-ring that I haven't had time to get replaced. I drive the car only once a week anyways so I was planning on getting the o-rings changed sometime soon, just not immediately.
Anyways, last night I am out for a drive and notice a little bit of smoke coming from under the hood, not a big deal, I know it's that little drip of fuel burning up. I drive around 10km more and trouble starts. I notice more smoke coming from under the hood. I check my rear view mirror and the car is literally blowing CLOUDS of black smoke out even at idle. It is just puffing and puffing it out.
I stop the car. I pop the hood and there is tons of smoke coming from the injector that was leaking fuel out of the o-ring. The car starts but does NOT have any power at low RPM. I can barely move it. I had to give it a fair bit of gas just to be able to park it in a proper spot. It stalls SUPER easy if I don't give it tons of gas and even then it moves slowly.
I can understand the smoke under the hood as a result of the o-ring possibly giving up at this point. But why is there TONS of black smoke coming out the rear? Also, why no power at low RPM? It stalls out if I don't give it TONS of gas.
Whats the best thing to do here? I am worried about doing any serious damage to the engine. I know I need to change the rings to fix the leak but now I am curious as to why the car barely wants to move. Does the no power at low rpm give any hint of serious problems?
Any advice/info would be appreciated.
nismobeyond is offline   Reply With Quote
Old 10-19-2007, 10:22 AM   #2
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
I'm sorry as i'm a CA owner myself but I seriously think YOU NEED TO BE SHOT.
NEVER EVER EVER drive a car that has a fuel leak ESPECIALLY when its leaking around the motor.
Heres a pic to show you what a tiny very tiny fuel leak can cause. This was caused because a compression fitting failed on the fuel return line, and the previous owner of my car butchered the lower wiring harness and because of built up grime and dirt I couldn't see the stripped ends. So the fuel shorted the wires causing a fire. Thankfully I wasnt driving as I was running diagnostics with my megasquirt.
MegasquirtCA is offline   Reply With Quote
Old 10-19-2007, 10:25 AM   #3
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
you have answered your own question
replace all the injector 0-rings
leaky injectors will also leak INTO the motor, just dumping fuel
and knowingly driving a car around that leaks fuel is stupid
rim_bender is offline   Reply With Quote
Old 10-19-2007, 10:49 AM   #4
nismobeyond
I know the risk I am taking is stupid and unnecessary but yesterday an emergency required me to take the car. I know exactly what can happen w/a fuel leak but yesterday I had no other options available. I'm actually living on a remote island right now, if I was at home I would have done the o-rings myself but there are neither good mechanics/parts available where I am. I don't have time to fully explain the situation but basically yesterday I NEEDED to be somewhere important and had to take the car. I'm not an idiot that would drive this car around if I didn't have to.
The black smoke out the exhaust was what was confusing the hell out of me so thanks for answering that, I didn't know fuel would leak into the engine as well.
