Old 09-17-2002, 08:24 PM   #1
KingKong8247
KingKong8247's Avatar
KingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of light
Send a message via AIM to KingKong8247
Hey I posted the other day about my high idle but no one replied. And today my idle went up to about 1800 RPMs Sometimes it goes to about 1000 but usually its pretty high. Why is this doing this? It was all fine till about 2 or 3 weeks ago I bought some octane booster from the dollar store to see if it would help any and it just raised my idle. Thanks for the help
90 240sx Coupe
KingKong8247 is offline   Reply With Quote
Old 09-17-2002, 09:11 PM   #2
luke91
luke91 is an unknown quantity at this point
I'll bet your throttle cable is sticking.  Disconnect your battery over night, one night, and if you still have a high idle, it's the throttle cable.  Just clean it up.
--luke
'91 fastback.  '97 S13 blktop SR20DET.  Cstm Frnt Mnt IC w/ cstm 2 1/2" piping.  stnls stl fltr.  3" cstm DP & exhst w/N1 muff.  Walbro FP.  ACT 6 pck cltch.  Go Fast Bits crnk plly.  Ground Control coils.  KYB AGX shks.  12.98@106 w/g-tech pro.  17psi.  All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 09-18-2002, 06:09 PM   #3
Russki
Russki is an unknown quantity at this point
I have the same problem, not sure if it's the same cause or not, but when my throttle position sensor is set properly, it idles at 1800-2000 rpm.  I adjusted the sensor all the way down to the lowest reading and now it idles at 800 or so, but that is just covering up the problem, not fixing it.  I have scratched my head over this many months now, and even the infiniti techs are puzzled.  One of them is very farmiliar with the 240's and he still didn't know what it was, I tried everything.  There is a small repair shop across ProjectD in Bloomington, MN that also know their 240's, but he said that it would take 2 days, 350 bux and he won't tell me what it is because he wants the business (obviously).  I hope yours is simpler than mine, but i guess i just wanted you to know you're not the only one with idle problems, they're very common.
Russki is offline   Reply With Quote
Old 09-18-2002, 06:17 PM   #4
240sxtreme
240sxtreme is an unknown quantity at this point
Send a message via Yahoo to 240sxtreme
check the throttle cable, also, if after checking throttle cable and it still does it...check the throttle body, make sure it's closing...
my car did that when I first bought it...I'm pretty sure it's the cable, cause it went away after a week of driving it...
also.....changing the TPS sensor won't be good, unless you're also making sure you don't rev over 6k...because if you lower the TPS by 1k, then the tach is 1k too low..so if it shows you're going 6k, you're really going 7k....Does that make sense to anyone else but me...(scratches head)
240sxtreme is offline   Reply With Quote
Old 09-18-2002, 06:26 PM   #5
Russki
That doesn't make sence because when i move the sensor, the actual idle goes down, not just the tach.
Oh yeah, and the engine shakes pretty bad at normal idle speed, but no power loss (at least i don't think so)
Old 09-18-2002, 07:01 PM   #6
KingKong8247
Hey, thanks for the replies.  I checked and its not the throttle cable cuz its definatlly not sticking.  Im gonna try disconnecting the battery tonite to see if anything happens.  It could be the throttle body but I dunno.  How would I go about checking that cuz my car doesnt start when the intake's off it just goes a little than stalls. Thanks
90 240sx Coupe
Old 09-18-2002, 08:33 PM   #7
DSC
New Title
DSC is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (luke91 @ Sep. 17 2002,12:11)</td></tr><tr><td id="QUOTE">I'll bet your throttle cable is sticking. Disconnect your battery over night, one night, and if you still have a high idle, it's the throttle cable. Just clean it up.
--luke</td></tr></table><span id='postcolor'>
What does disconnecting the battery over night do exactly?
DSC is offline   Reply With Quote
