Old 11-15-2007, 02:27 AM   #1
My_SilVia
My_SilVia is an unknown quantity at this point
Real quick, brake light and battery light
I was driving through some bumpy roads (SF has some shitty roads) and after a couple of bumps my brake light and battery light started flashing.
It was on for awhile until shut it off. Usually it goes away after a while or when i shut it off and start it up it goes away.
Am I in the safe?
My_SilVia is offline   Reply With Quote
Old 11-15-2007, 03:17 AM   #2
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
A start would be to check your brake fluid, and battery terminals.
projekt_s13 is offline   Reply With Quote
Old 11-15-2007, 07:06 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
also check your alt, as it may a have a loose connection, or the belt is slack.
japslapsilvia is offline   Reply With Quote
Old 11-15-2007, 08:19 AM   #4
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
i had a similar problem in a different car, check the harness going into your brake master cyl, one time mine wiggled loose. yeah clean your battery terminals too.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 11-15-2007, 12:10 PM   #5
PoorMans180SX
PoorMans180SX's Avatar
^^what they said.
Old 11-17-2007, 12:43 AM   #6
usajdm
usajdm's Avatar
usajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond repute
Id check all thats been mentioned and be sure to do a good check around the alternator.
Two times on two different S13s Ive had the belt loosen from either the bracket or tensioner......... anyways, causing the alternators charging to fluctuate, in return causing both "brake" and "battery" lights to trigger.
Ive been told by an elder(so yes, he does get the benefit of the doubt) Datsun/Nissan mechanic that the car was designed to trigger those two lights in the event of a "charging" problem.
Dont know if its fact but.....................
What the hell is "BALLER" or "GANGSTER" status, about a 240sx?
usajdm is offline   Reply With Quote
Old 11-17-2007, 06:42 PM   #7
ho1ywars
ho1ywars's Avatar
ho1ywars is an unknown quantity at this point
alternator, check connection (ground, hot), probably loose.
ho1ywars is offline   Reply With Quote
