![]() Join Date: May 2007
![]() Feedback Score: 10 reviews
Power FC User's help
I just installed my power fc on my zenki/s13 red top (62 ecu) and I wanted to know before I turned it on what settings I should put becuase I not fully stock. The fc is supposed to come with a base map.. Mods are as follows..
Injectors 550cc z32 maf 28 turbo fmic exhaust well the basic bolt ons.. I hope you guys can help..if you need any more info let me know.. also if I can't at least make drivable would I be able to use my stock ecu with the z32 maf. |
Never mind, Just read apexi pdf.. wont run unless its completly stock.. but thanks.. I still would like to know if the z32 maf would work with a stock ecu though if anybody knows....
yeh, there is a section to select the z32 afm... on default it will be standard...
as for your injectors, calculate the correct % in comparison to your standard injectors... this should allow you to drive to the tuner... i have the formula sitting at home somewhere :P |
