Old 12-12-2007, 05:57 PM   #1
Doluck
Doluck is on the path to ruinDoluck is on the path to ruinDoluck is on the path to ruin
turbo timer and alarm conflict
Anyone know how to get around this??
I'm putting a larger turbo and a timer on this car, but the turbo timer and alarm are conflicting.... it wont shut off.... When you take the key out it counts down, then it trys to shut off but the timer just starts over.
The alarm was already installed, I dont know any thing about that.... the TT was also already insatlled on another car, it was just unpluged and pluged in.. I shouldnt have had to change anything.. The TT is an Apexi and the alarm is Viper.
Doluck is offline   Reply With Quote
Old 12-12-2007, 06:00 PM   #2
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
does the viper alarm not have a turbo timer built in....
bigOdom1 is offline   Reply With Quote
Old 12-12-2007, 06:01 PM   #3
Doluck
Nope... its just a base model.
Old 12-12-2007, 06:10 PM   #4
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
Is the alarms starter kill relay wired in....where are the conctions of the alarm made before the turbo timer as betwwen it and ignition or after tt to the car?
nissan240sxkid is offline   Reply With Quote
Old 12-13-2007, 11:41 AM   #5
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
the starter kill wont affect the car once its on.
i would say its the ignition. the turbo timer is keeping the ignition on so the alarm thinks the car is on but your trying to arm it as if the car is off but the car isnt really off.
deesz is offline   Reply With Quote
Old 12-12-2007, 06:33 PM   #6
Doluck
wow.. NO CLUE!! I dont do alarms.... That why I dont under stand this.
Old 12-12-2007, 06:53 PM   #7
nissan240sxkid
sometimes the ignition wire or what ever you want to call it that laches the starter kill could be interupted....but every installer does alarms diff so if he made spaghetti, that might be where the problem is....what year car did the tt come out of and what did it go into?
Old 12-12-2007, 06:55 PM   #8
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
This is a very good question, i have been wonderign about this too, hope you figure it out, and let us know, i will be installign my ttimer on mine also soon!
an dwas worried that it might interfere
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 12-12-2007, 07:02 PM   #9
nissan240sxkid
my apexi has 2 wire hooked up constant and ignition from the tt I did not use a after market harness and mine works fine and I even have a viper remote start alarm combo and dont have this problem...If I remember I will make a diagram when Im at work
Old 12-12-2007, 07:21 PM   #10
Doluck
That would be great!!
Old 12-13-2007, 06:25 AM   #11
g6civcx
g6civcx's Avatar
Your ignition wire is looped between the TT and the alarm. When the TT shuts it off, the alarm wiring send current back through the circuit around the TT. So the TT is not controlling the ignition wire signal.
I recommending removing both the alarm and the TT and return the ignition switch to stock. Then we'll talk.
Old 12-13-2007, 11:38 AM   #12
deesz
alarm
i believe on most alarms there is a delay you can do. other thing that might work is auto arming only downdownside is that it wont arm till the turbo timer turns off.
Old 12-13-2007, 11:35 AM   #13
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
upgrade to the Viper 791xv than you'll get turbo timer. 791xv can be had on ebay for $170
MegasquirtCA is offline   Reply With Quote
