Old 12-13-2007, 10:21 PM   #1
jakethesnake
jakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymore
CAS moved around
i have a redtop s13 SR20DET..its not starting, im pretty sure that its my timing thats offor my CAS... i looked at my CAS and it loos like its been moved around...what should i do now?? should i just move it? or re-time the engine, ive searched around but i cant find what i should do
jakethesnake is offline   Reply With Quote
Old 12-13-2007, 11:56 PM   #2
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Check the FSM.
Then make sure everthing's set correctly.
Why is your CAS moving around? Did you perform any engine work?
The FSM gives you a step by step guide on how to set timing.
Be aware that the CAS is fickle. If it's not set exactly right the engine won't catch.
Good Luck!
HalveBlue is offline   Reply With Quote
