Old 12-14-2007, 05:34 PM   #1
u1fastwhitelude
u1fastwhitelude can only hope to improve
Exclamation rear caliper rebuild kit Problems HELP!!!
ok about 2 weeks ago my rear brakes locked up and caused my calipers to get red hot and glow. Well my right rear brake system caught FIRE!
so i put it out and the next day i changed my brakes and found the seal was toast.
i just bought a rebuild kit from auto zone. so i screw the piston off clean it up and now when i try to replace the seal it seems like its not long enough to stretch along the piston and seal it. i have to put the seal around the caliper first then push the piston in and try to screw the piston , it aint workin. so i then try the put the seal on the piston and then screw it in, this way would allow me to actually screw the piston in but the seal never did fall into the 'lip' of the caliper.
please help soon cuz i have to get this done tomorrow morning cuz i have to be a work at 1.
btw i have a 91 240 fastback
u1fastwhitelude is offline   Reply With Quote
Old 12-14-2007, 11:36 PM   #2
u1fastwhitelude
Bump !!!! Does Anyone Have Any Tips
Old 12-15-2007, 04:10 PM   #3
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
The seal should fit on there fairly easily. Maybe they sold you the wrong part?
mmdb is offline   Reply With Quote
Old 12-15-2007, 04:13 PM   #4
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
SILICONE SPRAY
helps rubber flex better for easier installs.
yeah baby.
Anto is offline   Reply With Quote
